Are there any tubeless plugs out there that people are using with success?
I have a set of Light Bicycle wheels and the tires are on there so tight I couldn’t even get a tire lever under the bead and had to cut the tire off to get it off. The tire was worn so I was throwing it away anyway but that wouldn’t work trail side if I got a flat.
I was thinking plugs instead of tape might make reduce the overall diameter enough to make easier. I’ve changed hundreds of tires on dozens of wheelsets, not an issue of technique.
