Running standard tires with tubes, no issue...remove the valve stem and install tube and tire
Running standard tires tubeless with sealant...mixed results, burping issues, some tires work better than others. If your trying to save weight, check out "tubeless ready" tires from Specialized, Bontrager, Geax, NoTubes, and Hutchinson. Standard tire casings but Tubeless beads so the burping issues are not a problem.
