Looks good to me, you want it like that, bead to bead.Hello! I am installing some tubeless rim take on my Dad's full rigid Sette Razzo, and we are not sure about the rim tape width. I never installed Tubeless rim tape before, so I am not sure if it is too wide or if we can get away with it.
Thank you all so much!
View attachment 2019360 View attachment 2019360
Yes, The rims got upgradedLooks good to me, you want it like that, bead to bead.
*If this is a cheap Performance bike (given that Sette is their own house brand IIRC), are you sure the rims are tubeless compatible?
I don't know. Got the wheelset used, so maybe. Also, it is very thin, it is 18mm Internal widthDid someone drill out those internal rim bed holes to be bigger? They look very sharp...
I haven't had to work on them but my LB road set with no access holes is awesome. Will probably go with that again whenever I need a new mtb set.You might want to shoot an email to the rim manufacturer and see what they recommend 👍
You'll find not every manufacturer has the same specs.
For instance:
WTB: 5mm wider than internal rim width
Alex Rims: match tape width to internal rim width
Light Bicycle Carbon Rims: 25mm regardless of width, just need to cover spoke holes.
