Another tubeless thread.
Awesome.
Any rim....and any tire....can be set up tubeless.
Whether you are capable of doing the fairly simple task is another question.
Did you miss the part about "tubeless" rims? Not rims that someone has made to run tubeless.
Logantri, we've talked some but I've had a few days of really low pressures lately and have been impressed with the Carbondales. Today's ride was one of those where when starting out I thought it was silly of us to be out riding. 4-5" minimum of new snow. I meant to go to 2-3 psi in front but when I checked it, 1 psi. It worked well there. The rear, I played with a little between 2-4 psi.
One thing I'm noticing and did a lot on today's ride is that the super low pressure in the rear isn't as helpful on the 85mm rims as it is on the 100mm rims. The tire rolls more and doesn't seem to be as stable on slight cambers. For what most people are riding, the 85mm rim is probably great, but for the very deep and often not well packed trails that I ride, the 100mm rim is better.
