Recently went UST tubeless (Hutch. Pythons at the moment), no troubles yet, but I'd like to be prepared when it comes time for a trailside repair. Searching this forum I'm finding a large variety of methods to repair tubeless tires. I'm wondering if I can get a consensus on things.
Super-glue repair: is any brand of super glue superior? How about different containers/nosel, are some easier to use then others? Is there any truth to or fact behind the people who say that wetting the hole first improves the effectiveness of the super glue? Some people say super glue will fix the flat indefinitely, others say only for a week or so, is there a consensus? Does tire brand matter?
Patch kit: Clearly you have to clean the area of the hole, but what about sanding? Some people say sanding is a no-no, is that true? Does tire brand matter? Will this work as well as the tubeless specific patch kit (perhaps if you're very careful about cleaning the area where you will be patching (ie, must be done back in the shop))?
Special tubeless patch kit: Are these different from standard patch kits? Are they the same as car tire repair kits? How much do they cost? Where do I get one? Are some better then others? Does tire brand effect effectiveness?
Sealant: Sounds like it would work well, but I'd rather not add the extra weight, and I've heard some nightmare stories about blow outs with a big latex mess all over the place. And I assume if something goes wrong with the sealant, you can't field repair the tire with another method. unless you're able to clean out all the sealant?
Spare tube: Most people recommend carrying a tube as back-up. Seems reasonable, however, do people think the other methods are effective enough that the tube can be skipped to save weight while racing, etc?
