Hello. I have a newer bike I am looking to convert to tubeless and had a question before I move forward. I've added Stan's tape to the rims and inflated tubes for 24 hrs to help conform the tape. After that, I deflated and removed the tube, and then inflated it without sealant just to do a test run. I got busy for a couple of days and they sat without sealant and leaked down to pretty flat but not completely flat over probably 48 hrs or so. I did a simple leak test and it looks as if the small leaks are around the bead of the tire. I just wanted to ask before proceeding forward, does this sound like a case of a rim and tire that don't work well together for tubeless or is this within what you would expect for a tubeless setup without sealant in it? I know the job of sealant is to seal any small leaks, but i didn't know if small leaks along the bead without it were within the range of what is considered acceptable or if it means I need to look for a more suitable combo.
Thank you.
Thank you.
