1 - 7 of 7 Posts
Discussion Starter #1
i replaced my presta specialized tubeless valve stems with Stans Presta valve stem with a removable core on my Custom DT Swiss X420SL rims and having a hard time getting a seal around the valve stem base . i even added extra stans...:cry:
any suggestions?
Former Bike Wrench
any suggestions?
Which Stans valve did you use? If you are using the Olympic Valve Stem it will not seal as it is made specifically for the ZTR rims...you should be using the UST Valve.
Discussion Starter #3
sorry.. i used the COFF'E CAFFELATEX TUBELESS VALVES PR
Discussion Starter #7
thank you
1 - 7 of 7 Posts
