Lezyne? I just got their classic pump and am so pleased with it. Of course I too have not tried it on tubeless for seating but just the pure action of the pump and the awesomeness of the chuck is worth it to me.
But is it sexy? Does it make you feel fine about yourself, cause mine does.shiggy said:I recently bought a Topeak Joe Blow Mountain.
Bonty 29 x 2.0, Zero to 30psi in 10 strokes.
UST spec / TLR tires and rims do not require the valve core to be removed to seat with a floor pump, even a normal Joe Blow Sport. I do it all the time.bsieb said:Are y'all taking the valve core out?Even my BIG stationary shop compressor won't inflate new installations reliably with the valve core in place. I will inflate with a tube overnight rather than fight with a new tire. So I'll try the floor pump but not selling my compressors. The pump is a joy to use I must say.
i own the lezyne cnc floor drive and the cheapest craftsman air compressor, i think it was 79 bucks. the lezyne is a great pump but nothing beats an air compressor for setting up tubeless. nothing.bsieb said:Cheaper?
http://www.hucknroll.com/lezyne-classic-dirt-floor-drive?CMP_ID=SH_FRO011&CMP_SKU=LED0104&mv_pc=r126
I question faster or easier too. :skep:
yeah yeah, i don't fight tubeless anymore and time is NOT of the essence, but the noise issue is important to me. And unless you maintain pressure all the time (even noisier) you have to let it air up, which takes time too. I do use all ust wheelsets at this point, not sure what maxxis ignitors and ardents are considered as far as TLR. Like I said, I have pretty much bottomless air available but that doesn't always help.scoutcat said:i own the lezyne cnc floor drive and the cheapest craftsman air compressor, i think it was 79 bucks. the lezyne is a great pump but nothing beats an air compressor for setting up tubeless. nothing.
Those are standard tires, not intended for use without inner tubes.bsieb said:yeah yeah, i don't fight tubeless anymore and time is NOT of the essence, but the noise issue is important to me. And unless you maintain pressure all the time (even noisier) you have to let it air up, which takes time too. I do use all ust wheelsets at this point, not sure what maxxis ignitors and ardents are considered as far as TLR. Like I said, I have pretty much bottomless air available but that doesn't always help.
Half the price and twice the speed is pretty sexybsieb said:But is it sexy? Does it make you feel fine about yourself, cause mine does.![]()
I always thought expensive and slow was sexy. You can have any two: cheap, fast, durable.shiggy said:Half the price and twice the speed is pretty sexy
I do not consider the Topeak cheap. The Lezyne is expensive. There is a point where additional cost does not mean better.bsieb said:I always thought expensive and slow was sexy. You can have any two: cheap, fast, durable.
I personally haven't had a problem with the removable valve cores, but i can see it being a problem in some cases.Coldass said:The Lezyne pump - valve connector screws on the presta valve head. I have found an annoying issue with the design.
If you use removable valve cores - useful for tubeless - it can back out the core on removal of the Lezyne head after inflation. This of course deflates the whole shebang. I have found I have to really tighten the cores or add a drop of locktite to use the Lezyne.
+1 for the Joe Blow Mountain. Fastest floor pump I've ever used, and it'll even air up a car tire in a reasonable amount of time. I've found the gauge to be very accurate as well, which is a nice bonus. I got mine for under $25 shipped on eBay, so that extra $60+ bucks in my pocket is all the "sexy" I need.shiggy said:I do not consider the Topeak cheap. The Lezyne is expensive. There is a point where additional cost does not mean better.
:thumbsup:shiggy said:I recently bought a Topeak Joe Blow Mountain.
