Just Stan's ...
dusty said:
I mean who has made their own sealant. I'm curious whether Stans is a special innovative formula (in which case I'll try it) or just repackaged liquid latex or auto tire sealant. Still, good to hear the Stan's seems to be working for you HTail. As fall gets closer I'm dreading the goatheads (usually one flat every 1-2 long rides). The only measure I've taken so far is that when I put on some new tires I used the Specialized "Racing Thorn Resistant" tubes, which may be just marketing hype (they're thin and 175g). Really won't know 'till late August.
I also am just using Stan's -- I haven't tried making my own yet. Stan's doesn't cost
that much, and it works. (I'm not on a tight budget, so success is more important
to me than cheap.)
I have an Elly Truth, and I've switched to Stan's on both front and rear. The stop did
the front, and I braved it out and did the rear -- right b4 a long ride! And it's working
fine. Just follow Stan's instructions on pumping up the tire (and using soapy
water) and you'll be cool. (Stan has a patent on his formula, so I'm guessing it's
not easy to reproduce, but who knows.)
I have non-UST rims and tires, and it's holding air great. And it's nice to be able
to run 35-50 PSI in my tired w/o fear of pinch flats.
Lastly, I now have the added benifit of thorn resistance. We have many many
goats head here, as well. (Seems like most are in my friggin' yard!) I never wanted
to run goop in my tires before, but now the Stan's seals the tires. I haven't had
a flat since I Stan-i-fied.
