Hey all,
There have been a couple good posts about converting the fatty's to tubeless. After 3 flats at the Brown County Breakdown, and a couple the week before that, I am over tubes!
I ordered some Q-tubes 24"x 2.1 - 2.3 presta , wasn't sure if they would be wide enough but they were cheap so I ordered 3 and took a chance.
I pumped the tube up to probably 36" and let it sit overnight so it would stretch out (hopefully).
I carefully cut the tube down the middle with scissors, then pulled my Larry off the front rim & got the old tube out of the way. I initially tried just the split tube & Larry, but it was a bit loose & could tell airing it up was going to be hit/miss.
I had some left-over sill seal foam from when we built our house, so I used that, cut down to about 1.75" wide. Put in 2 layers on the inside of the rim, basically making the inside channel flush with where the bead sits, but still away from the edge where the bead needs to seal. Stuff is light as air & should hold up well. Couple pieces of tape to hold it in place.
Installed the split tube again, & carefully put Larry where it needed to go. With some messing around you could probably get it to air up with a floor pump, but I had my air compressor handy so I used that. Aired up first try!
It went so easy that I decided to deflate, break the bead, and add some Stan's sealant. In the future I will use the Stan's injector & pull the valve core to add more.
I was surprised how hard I had to press to get the bead open, even with no air pressure inside, so that is a good thing. Only had about 6 Oz of sealant to stick in, picking up more tomorrow, so I put in what was left, re-seated the bead, & hit with air again.
Sealed up nicely the second time! Nothing bubbling around the edges so looks to be a tight seal.
:thumbsup:
It is raining (of course!), so no testing yet, but will report back once I try em out. Will be some good dirt riding singletrack, then once the snow flies I'll air em down & see if it still holds.
Converting the rear Endo will be next!
The profile of the Rolling Darryl rim looks like you might be able to do the "Gorilla tape" method. If for some reason the split tube decides to be a pain & let me down, that will be the next.
:thumbsup:
