Can someone explain how the CBF concept is (or acts differently than a single pivot), given the IC stays right in the same spot as a single pivot would? Just trying to understand the technical details. I owned a Riot and thought it rode great.
Jaks,Can someone explain how the CBF concept is (or acts differently than a single pivot), given the IC stays right in the same spot as a single pivot would? Just trying to understand the technical details. I owned a Riot and thought it rode great.
Yes.I guess the confusing part is the IC vs the CC. If you put a singe pivot right where the CC is on a Riot, would the bikes act differently, and why?
Single pivot with a floater and idler at the pivot get it done also.Yes.
If a single pivot rode as good as a CBF or any multi-link bike- the industry would have never built anything but single pivots. The magic is how a multi-link suspension can isolate the brake and pedal forces.
Pretty sure weight weenies stopped being the main focus of frame makers many moons ago. Added drag from an idler is minimal, and floater adds none. It's actually a good, simple solution, but you're right; majority of buyers these days would likely rather have something complicated, expensive, and hard to keep going long-term. Cuz 'progress'.Floater and idler would add weight and drag so weight weenies frown on that, unless it's on a down hill bike. I don't think majority of consumers would would want it either.
yes- but only the I-track versions of the idler. Like the new Commencal and Norco or the old Balfa bb7, if they added the floater....Single pivot with a floater and idler at the pivot get it done also.
Looking at pics of those - so the idler position changes as the suspension cycles?yes- but only the I-track versions of the idler. Like the new Commencal and Norco or the old Balfa bb7, if they added the floater....
An idler on the pivot will pedal like a BB concentric pivot. Very inefficient. The CHAINLINE is the key. If not directed at the IC or single pivot point it will pull into the travel with every pedal stroke. (It's a tug-of-war game, above the pivot = pulling into travel. below the pivot = pulling down.)Looking at pics of those - so the idler position changes as the suspension cycles?
What does that gain versus a static idler position concentric to the pivot point of a single pivot, add some pedal feedback back in?
Interesting, thanks.An idler on the pivot will pedal like a BB concentric pivot. Very inefficient. The CHAINLINE is the key. If not directed at the IC or single pivot point it will pull into the travel with every pedal stroke. (It's a tug-of-war game, above the pivot = pulling into travel. below the pivot = pulling down.)
Jackshaft does TOTALLY isolate the chain-stretch/pedal-kick from the system. Although they have the same Anti-squat as the BB concentric pivot.Interesting, thanks.
So maybe a jackshaft rather than an idler would be better as far as isolating the suspension from pedaling forces (though it sounds like totally eliminating them is not really the ultimate goal for most designs, rather being able to dial them in)?
:thumbsup: Thanks for confirming. Been trying to make some decisions on a (hopefully near-)future build. Thinking an idler is probably good enough for me, though I kinda like the idea of being able to run SS on an FS.Jackshaft does TOTALLY isolate the chain-stretch/pedal-kick from the system. Although they have the same Anti-squat as the BB concentric pivot.
The idler is light and simple to do.
