1 - 9 of 9 Posts
Why so uptite?
trying to decide between the:
Rockshox Reba
Fox F100RLT
Manitou R7
I like parts of each fork and i am not sure which on to buy. Suggestions?
This is for my Superlight that has a Push'd Fox rear shock.
thanks.
Angry bunny
Rockshox Reba
Fox F100RLT
Manitou R7
thanks.
Looked at the Fox but ended up running the Reba SL U-turn on mine.
Could not be happier.
Air adjustable.
85 - 115mm of travel adjustable externally.
Lockout, but with blow off in the event of a big hit while locked.
32mm stanchions.
Waaay cheaper than the Fox without sacrificing features or weight.
Why so uptite?
Discussion Starter · #3 ·
thanks. can you measure from the center of the front axle to the bottom of the steer tube for me on your reba setup? I want to see what the length of this fork is compared to the others. I don't want to raise the front end of my bike anymore than it is now.
Angry bunny
At what travel???
The Superlight is originally made for an 80mm fork but moire recently for a 100mm fork.
I run mine at 100mm most of the time and adjust it down to 85mm if I am climbing or doing lots of fireroad riding.
Length is approx 470mm at 85mm.
Why so uptite?
Discussion Starter · #5 ·
TR said:
At what travel???
sorry. i forgot to add at 100mm of travel. Thanks.
mtbr platinum member
458 (85mm setting), 473 (100mm setting), 488mm (115mm setting) axle-crown. A good site here to compare the axle to crown measurements.
Why so uptite?
Discussion Starter · #9 ·
thanks ryan. I left a mssg on friday with the mtn high cycles guy to see what kind of prices he has. I still haven't heard back. But after your story with him i think i will call him again tomarrow. I have a feeling this Reba will work out well as long as i can get a model with bosses.
I went riding this morning and now the sid is leaking severly, it appears i lost all the oil and all the air in the 1 side. I guess that was my notice to get my act together and get some new parts ASAP..
1 - 9 of 9 Posts
