Hey everyone.
I've got a question maybe some can help. My '04 Hollowpoint sport is only 6 weeks old and the Truvative ISIS SL spindle is already shot. It was loose and creaking so I had the mechanic where I bought the bike take a look. There were a few drops of water in the bottom bracket and the spindle was loose and kind of grinding. Appearantly water got into the bearings.
I've done a bunch of stream crossings but never totally submerged the BB. He band-aided it with White Lightning :-/ because you cant get into it to regrease, so its on borrowed time.
I've been out of the loop for a while, and don't know too much about all the new splined spindles and such. My last tapered Shimano spindle has lasted over ten years.
So my questions are:
Are current spindles so fragile that a few good stream crossings will ruin them?
Or, is the one that came on my bike a POS design, and I should upgrade next time?
Should it be a warentee issue?
Basically I'm trying to decide between buying a good one that will last (hopefully), or cheap disposable units.
BTW, also, a tooth on the small sprocket of the cassette BROKE off, and Performance replaced it without a hassle. But no luck with the spindle.
Thanks, Brian.
Thanks, Brian.
