1 - 3 of 3 Posts
· Registered
Is a Truvative Noir Carbon crank coming off of a Gary Fisher Superfly 100 with the integrated bottom bracket (90mm) compatible with a 73mm standard. I realize you would need the external bottom bracket is the crank and spindle any different on this crank not allowing it to work with a standard bottom bracket?
· Registered
Discussion Starter · #3 ·
mtnbiker72 said:
Truvativ cranksets are not compatible with Shimano/Race Face/FSA Alloy external bottom brackets if that is what you mean by "standard".
It should work fine with a SRAM/Truvativ BB or compatible models from King, Hope, or Enduro.
That's what I was hoping. I will get a King or SRAM bottom bracket. Thanks for the response.
1 - 3 of 3 Posts
