I am having some trouble with the installation of a GXP BB into my 2009 Fuel EX 8.
In the instructions it tells me to put one spacer for each cup, but if I only use one on the drive side, the granny gear teeth touch the frame.
The Shimano Hollowtech II I had on there before had 2 on the drive side and one on the other, but the GXP only came with 2 spacers total and not with 3.
The GXP cups themselves are wider than the Holowtechs, but still not wide enough to use only one ring on the drive side like instructed.
If I reuse one of the spacers I had from the Holowtech, I fear that the cups are too wide apart from where they should be. Also, if I use 2 on the drive side of the GXP the crank sticks out further than it did with the Shimano setup. Like I said, the GXPs have wider cups.
Does anyone have any advice?
Thanks,
D
Thanks,
D
