I have an ID and my beaings were not rolling to good when they were mounted in the pivots. It turns out that the hard anodizing and the shot peening of the parts made the seats for the bearings smaller. I took some 300 wet/dry and sanded the inside of the seats in the stays and swing arm now they roll smoth. The other problem this caused before I fixed it was the bearings were being squished too much and that let water in through the seals. I took the bearing apart and cleaned and regreased.Little Frog said:
Also you would have more problems with your bearings if they were not tightened enough. Then you might get noise from the inner race moving on the bolt.
Did you check your pedals? I have Time pedals and sometimes my cleat rubs and makes a creaking squeaky noise.
