I true my wheels when they are on the bike. Turn the bike upside down and use the brake pads (if you have V brakes) as guides or put some zip ties around the chainstay or fork legs and cut them where they almost touch the rim.
First check for any spokes that are looser than the others and tighten them up.wildkyle90 said:So, i dont have a wheel truing stand, and they can be a costly investment for someone who doesnt bend wheels often.
Is there a good way that works to true your wheels without using a truing stand?
I guess you mean a commercially made truing stand? Of course there are many good ways. Check the pics in my sig info.wildkyle90 said:Is there a good way that works to true your wheels without using a truing stand?
Man, sounds like those were awesome times! Any actual tips or advice you brought back with you from the 80s?Ive trued and built roughly 100 Plus wheels over the years. Back in late 80's i used to watch the local wheel builder and pick up tips...saves the pennys..even those crisp like wheels can be saved..remove spokes and bend the rim slowly till near straight as you can and Re-lace/ true..
Lmao...thanks!Man, sounds like those were awesome times! Any actual tips or advice you brought back with you from the 80s?
hello, yeah that guy could save many a wheel..and its kept me from taking my wheels to the shop..just watch and ask next time your at the bike shop as they true wheels..Man, sounds like those were awesome times! Any actual tips or advice you brought back with you from the 80s?
I would have loved to have checked the spoke tensions for being equal after he was done.hello, yeah that guy could save many a wheel..
By the late eightys he'd been building wheels for 20 odd yrs. .I would have loved to have checked the spoke tensions for being equal after he was done.
I think Mike's comment was directed specifically at "saved wheels", not necessarily implying a tensiometer is a required tool for wheelbuilding.built and trued 100's wheels in the 80's. spoke tension was pretty much checked by touch and past knowledge back then. I knew several other good wheel builders back then. a tension test tool was never even a glimmer of a mention and we built lots of high end light sometimes to light weight wheels. without fail. sometimes knowledge outweighs a gizmo. and personally I don't understand how any rider past their first year cant true up their own wheels. but its a new world of cycling, you ride it then drop it off to some guys to clean and tune it up.
