First of all, I am not any kind of authority on light testing. That being said, I always view these types of test results with skepticism. Evidently L&M hired the cited firm (Deepsea) to conduct an experiment comparing lumens of L&M lights with others. I looked at the graphs that plot something called uW/nm on nm. L&M claims the area under curve (i.e., integrate the function between two given values of nm described by the curve) is "more light" and imply more area means more lumens. But we have no way of knowing if the results are significant. Most experimental designs take into account replication, which means you average the results of several tests. Impecision in testing procedures means you need to replicate results to identify whether the observations are really true or a consequence of random experimenal error (anybody remember "cold fusion?"). The form of the results, for example Cygo Tridenx has 381.7637 lumens, implies a level of precision that I suspect is not really there. L&M cites an important feature of the data is that the lights were tested to a NIST standard. What that means is that the contract lab has periodically calibrated their testing instrument using some device that is traceable to a NIST standard. That means that their test results are reliable. Clearly that is a good thing, but just because your equipment is calibrated doesn't mean that your experiment and its analysis is correct. As long as they are citing NIST, they should have cited the test method used (ASTM, ANSI, or whatever) so we could properly couch the results. I would imagine there must be various methods of measuring lumens and probably each method means something a little different. Another issue is that this is not really an independent study, and to their credit L&M is careful not to claim that it was. I think L&M just hired a lab to run tests and it could be more accurately described as independent testing. An independent study means L&M would have turned everything over to a independent firm to conduct the study. Maybe they did that, but it's not what the info says. An independent study would be a lot more credible. Such testing would be blind, i.e, the testing firm does not know whose lights they are testing. There should have been a placebo (for example, an L&M light with "lumens" purposely dialed down to see whether the testing caught it) used so that we could judge the reasonableness of their data and experiment. Similarly, it would make most sense for the independent lab to collect the lights to be tested. Maybe they did that. Probably the best evaluation would have been for the independent lab to test lights that been in service for a given period of time.
Lastly, these results would mean a lot more if they were published in a peer reviewed professional journal. I would not normally bring that up, but somebody above mentioned that the study was "published" which probably is not true. If L&M is going to market their products with what they want us to think is a sophisticated scientific study, then I believe it is fair that their science be questioned. Maybe I missed it, but this experiment is not even mentioned on the deepsea.com web site much less published. If this study has been accepted by and published in a credible, peer reviewed journal, then I gladly stand corrected on all my points.
Bob
