this is totally fine and there is nothing wrong with mounting yakima locking blockheads or thule locking lowrider racks with this applications. we just talked about it here, and don't see a reason to seal the outside of the block with silicone, or use rubber washers. i don't see it being a bad idea either....not doing that wouldn't be a dealbreaker for me.
maybe someone else has some insight why they would suggest that that i'm overlooking??
if you were going to nut it on the under side, you could use a little primer on the drill hole.
just make sure that where you mount them, your handlebars and pedals wont' interfere with the cab or wheelwells and you mount far enough forward to accomodate your wheelbase.
