1 - 2 of 2 Posts
MN/WI
Anyone else have the issue were you can rock the wheel back and forth when the TRP Spyre brakes are gripping the rotor? I also get a clicking noise on the front brake when I first pull the lever. Thanks...
A God Without A Name
A clicking noise when you pull the lever is often a sign of an overly loose brake cable. A little play rocking the wheel front to rear is usually just pad slop, which most disc brakes have. It annoys me too, but it is harmless and even my Dura Ace Hydraulics do it. Though I have noticed direct mount calipers do it less.
Sent from my LG-LS993 using Tapatalk
1 - 2 of 2 Posts
