Hmmmm...the speed thing
okay, you are partially correct....speed IS your friend. On a double, Ill take an overshhot vs coming up way short anyday. Thing is, alot has to do with your form on the jump as well as speed. Its really less an issue of speed being your friend and more of brakes being your enemy. DO NOT brake as you approach. Itll screw your rythym all up. Think flow, think floating, and trust the lip most of all. In a nutshell, if you are backing off, just go a bit faster than you feel good with (not a ton, mind you) and be sure you are keeping your weight neutral throughout the takeoff. Basically, let the radius (curvature) of the jump determine your trajectory. The more you fight that, the less likely you'll jump it well (and safely) even if you are going fast. Relax, and trust the lip....trust the lip......trust the lip.........
