1 - 20 of 110 Posts
Hi all,
I've been working on a new design as I've been a bit bored at work this week...it's going to be a Triple Triple XPE. It's only in the early stages of design but I'd appreciate any feedback regarding the design, optics, driver etc.
The pic is just a screenshot from my masterCAM drawing:)
Here's the good bit ( I think)....the 2 pods on the side are going to be rotateable so that the beam can be customised for angle. By using different optics you shoud be able to get a really good beam pattern that would give a nice flood (using a wide or elliptical optic) good miidle light (using a medium) and nice throw with a narrow...
Let me know what ya think please :thumbsup:
Cheers, Steve
Lets RIDE!
That's a wild looking housing D! Are the side pods adjustable only up and down, or ball-and-socket style for any-angle adjustment? I've been thinking about a triple xr-e design with vertical adjustment on the outer two leds, but it's not nearly so exotic (no CNC mills in my basement).
JZ
Aren't you afraid that with wide angle optics in the sides, light could reflect on the central section and cause some glare in the cyclist eyes?
Discussion Starter · #4 ·
Thanks JZ,
Yeah, they are only adjustable in the vertical, the optics should do the rest (I hope).
Calina: The front section is only about 8mm proud of the pods so reflected light won't be a problem.
Steve
Great looking design.
What is the real world size? ~100-120mm wide or?
I am probably interest if the size (and cost) are reasonable.
/Håkan
SWEDEN
Discussion Starter · #6 ·
Hey Hakan,
Thanks :thumbsup: How did you get on with the other housing? At the moment, the housing is approx 90mm wide, 40mm high and 50mm deep. As it's just the initial design, I'll be looking at reducing the size (if possible) and trying to save some weight. Mind you, I don't even know how much it will weigh yet :madman: so it may already be superlight once I get to machine one.
I'll add some more info once I've got the prototype done. Need to place an order with cutters though...
Steve
[quote]Let me know what ya think please ....
mmmm yummy ... please sir can i have 2 of those squarey roundy middley bits in one piece
a dooble triple, run 6 series on a nFlex with a 6 cell battery (big bright, big runtime)
mount at back switch on top, dc in bottom glass lens protect the optic
black ano ............ `kin killer light :thumbsup:
Discussion Starter · #10 ·
Hey Graham,
If you think it's small now you should see it once I've made it smaller....:thumbsup: I reckon I can loose about 20% of the current size! It's just a prototype at the moment so will see how it works once I have enough dough to order some LED's and optics from cutter...I reckon it could be good!
I initially designed it around the hipFlex but as the maxFlex will do fine, I'll be able to make it quite a bit smaller. Just need to get on the lathe so I can turn the side pods.
You'll be 1st on the list if I do a few to sell:D
Steve
Five is right out
The design on paper looks like a blaster part out of Star Wars :)
Tripple tripple? What sort of battery pack are you thinking of feeding into that?
Ok Deesta... stop this. I already have one of your creations. Don't make me pine for another. ;)
Great work. Top notch stuff. :thumbsup:
Discussion Starter · #15 ·
Thanks for the comments guys.
womble: I'll be using a 15v 5.4aH Li-ion, driven by a maxFlex :)
racerdave: You DON'T have to buy one :D I've really got the bug now...I guess I'm a bit like troutie, I spend a lot of time at work sketching out possible options on what would/wouldn't work. I reckon this one will...and the adjustable beam angles should work really well too.
I've had a bit of a play on my CAD/CAM today and have managed to shave 2mm off the outer size. That takes it down from 40mm to 36mm. Should save quite a bit of weight, the centre body was 110g (with screws/switch and a dummy maxFlex in)
aka RossC
Hi Deesta,
Why the maxflex?
It has a max output of 1.2 amps, so if you are going to parallel the three strings you will only be able to give 400ma to each LED. It would think your housing will be able to cope with more heat than that! :devil:
If you are going series, then it is a massive Vf and will smoke the maxflex.
Just thinking about how bright this could be if they were all running at 700ma :thumbsup:
Discussion Starter · #17 ·
Hey OBS,
If the maxflex isn't upto it, what would you recommend? HipFlex?? The electronics side of things is where I go wrong :madman: Still a newbie in that respect
Steve
It is a very interesting concept and I am thinking it would lend itself to using a quad in the centre and 2 triples in the outers . this would then give you the even number to split in to two strings .
But I like the concept of 2 drivers here 1 for the quad in the middle and 1 for the outers
so you can have either on at any one time . so maybe a controlable driver for the centre
and a cheap dumb driver for the outers
Very nice.
I don't really need another light, but depending on the price I may not be able to resist.
Keep up the good work.
1 - 20 of 110 Posts
