Triple Crankset Conversion Questions
896 Views 9 Replies 7 Participants Last post by  Frs1661
I have the M543 and was taking it apart last night and had a few questions.
1. Does the middle ring go behind or on top of the crank arm?
2. Do I need a bashguard? If so, would grinding off the teeth on the big ring work?
3. If I did need a bashguard, would shortening the chainring bolts be a bad idea?
1 - 10 of 10 Posts
1. Does the middle ring go behind or on top of the crank arm? Behind
2. Do I need a bashguard? If so, would grinding off the teeth on the big ring work? grinding off the teeth will work. Has worked for me and its a cheap fix. Or, you can buy the shorter chainring bolts for not having the bashguard.
3. If I did need a bashguard, would shortening the chainring bolts be a bad idea? I would just get new chainring bolts. New, fresh ones.
These would work: http://www.danscomp.com/459003.php?cat=PARTS
Thanks for the link..
I might go the cheap route just because I want to play with my power tools... Wonder if my Rotozip has an attachment... hmmmm
Bench grinder
Use a bench grinder to grind off the teeth.
Personally, I leave the teeth. They dig in to large logs very nicely.
Just a matter of preference.
Yeah, and they dig into flesh quite well too. But if that is your preference??? Check the price of a bashguard and the price of a large chain ring. Its not a huge difference but pennies make dollars. That is of course, if you are saving your parts to possibly go back to gears.
http://www.jensonusa.com/store/product/CG406C00-Shimano+Saint+Chainring+Guard.aspx
http://www.jensonusa.com/store/product/CG407A12-Shimano+Lx+M580+Chainring.aspx
Do what you find easiest. But post pics.
Good Luck
Save yourself some grinding time. Snap the teeth off with a pair of electrician's pliers, then grind off whatever remains. If your ring is anything other than aluminum, all bets are off.
--Sparty
The chain should protect the ring. Just get the steel Truvativ dual hex head bolts for use with a single/double ring. They come with washers that will space properly for use with a single ring, or remove them and run a bash. Plus they're pretty cheap.
True about the chain part. If you really want a bashguard look at the BBG Bashguards. They are both nice AND cheap.
I have bent chain rings on my SS while hoping over logs and rocks without a bash guard. The chain will save you from marring up the teeth of your single ring, but bending is more the concern here IMO.
1 - 10 of 10 Posts
