No. Just get a crank remover.aaron04 said:I need to pull the square taper cranks off my bike but dont have a puller, is there anyway to do it without damaging anything? Thanks! Aaron
It was a slight pain to use but it worked ok, I can see how a real crank puller would be much easier! I was going to make one but I couldnt find a bolt that large with the same threads as the crank. I was going to cut the end off of a bolt, drill out and tap the center so I could run a smaller bolt through it to press the crank off. I went ahead and ordered a crank puller from PricePoint for the next time.Bikinfoolferlife said:Not ever having pulled a steering wheel I had no idea, but now that I think of some I've seen, that was cool you could use something already in the toolbox...
