Rigid dinglespeed monocog. Track fork end.
Just re installed my double chainrings, 32 on inside and 36 on outside. everything is oval and out of whack. I have a very tight chain then when I spin it 180degrees it's mega loose. I've tried to adjust most of the play out of it but when I get the inner one right, the outer one is wrong. Is there a trick to getting them both even?
Now the problem, I ran it like this for about 2 hours yesterday I KNOW it was too tight but ran it anyway because I couldn't get the adjustment right, when I was done my wheel was loose (not the dropouts, the actual hub was shaking back and forth even with the bolts tight. ALSO... My bottom bracket was slightly loose, I don't have the tools to fix either of these problems so LBS tightened it up and said it was good. Well today I'm riding and every time I go to CRANK on the pedals i'm hearing a loud pop especially if I'm turning and the rear of the bike seems way too flexy from side to side.
Is it possible I screwed up my wheel wheel big time?
