got the first mtb ride of the season in today,a nice 20 mile local loop. I wanted to start a new thread instead of bumping the old one's, so here goes.....
Bike; 2006 Stumpy FSR, base frame up build, 05 Vanilla R-Pushed, king, Thomson X4 stem, XT cranks, XT FD,XT cass, Sram X9 RD, Sram triggers, Avid Speed Dial levers, Avid mechanicals with Power Cordz fiber cables, very sweet. 03 S Works wheelset, Mavic X317's with Hugi 240's, Roll X Pro's D2's with Stan's, and a Rival SL saddle, Specialized seatpost, clamp, mid rise bar, grip's, as well as Ritchet stubby bar ends. 28.25 lbs on the Ultimate digital scale-bottle cage and cyclometer included.
I rode the Stumpy all last year with the Triad, and the Vanilla set at 4" of travel. I fiddled with the Triad almost constantly. Mid season I sent it to Push to have it serviced, seal's, nitrogen charge, and fluid, that's all the service they would perform on the 06 version of the Triad. When I got the shock back it was different, but not much better. It worked best in open mode all the time, but would ride too far into it's stroke. I continued to fiddle with psi, and the damn cheesy lever. I finally got an RP23 from a Cdale Rush around December.
I got two chances to ride the bike with the 23 installed in early January. We had a great warm spell here in Central New York, and I got about 30 miles in. Within the first few pedal strokes, I could tell the 23 was light years ahead of the Triad. Very frim under pedaling, great acceleration, much more responsive to trail impacts, and the bike rode higher, cause the 23 didn't sag so much into it's stroke. At the end of the second ride, the 23 stuck down...
Move ahead to spring here in Central New York. I did the air sleeve maintenance on the
23, bumped the Vanilla back out to 5" travel, and finally got the Roll X D2's to seal with Stan. That is alot of variables to consider on the first ride, although I have used Stan for many seasons, I just couldn't get the D2's to go tubeless when I got the new set mid season last year..
So...here we go. I set the sag for both the 23 and the Vanilla according to Fox. To get the correct sag from the 23, I put in 200psi, that's about 10# above my riding weight with gear. I backed the Propedal lever down to level 2, I had only tried level 3 last time out. The bike felt a little higher in front-remember, I now have 5" travel up front instead of 4, but that sensation would fade. I feel pretty comfortable with the psi on the 23, I used most all the travel, but I think I could slow the rbound down another click. The climbing was great, I didn't notice the longer travel front fork, didn't have to search for an efficient position. Stan helped here too I'm sure.
So, advantages with the RP23 vs the Triad. Massive improvement in pedaling efficiency and especially acceleration, great traction and ability to hold the line while climbing too. But the best advantage so far, the bike performs great with the 5" stroke fork. Definately still has an XC feel to the geometry, steering was very sweet indeed.
I have quite a few road miles in this year, so my legs are strong, time now to work on the bike handling skills again. The 23 and the bumped out travel on the Vanilla, just raised the competency of the chassis even more. Now I'm more the weekest than before, gotta get busy, the next ride is Sunday
