1 - 4 of 4 Posts
Greetings I was able to pick up a trek stache frame and build it out with the help of a bike shop so the question is that it's a 12 speed on there and the chain is very close to the frame in 11th gear is that normal? There is an inside chain protector on the frame so I'm guessing this was expected
Tire Wheel Bicycle Bicycle wheel rim Bicycles--Equipment and supplies
2018 Trek Stache
Chain will be close but you have to run the non-boost crankset, i.e 7100-1,8100-1,9100-1 with a 152mm chain line if you want to use Shimano. Also the maximum chainring size will be 30t.
1 - 4 of 4 Posts
