IF the Izumi is 1/8" width, you can use a 1/8 half-link to effectively move the wheel back. The narrow-wide chainring won't care, as long as the 'narrow' part of the chain clears the wide teeth.
Really simple I just used the Surly single speed kit from Jensen.I am looking to convert my Stache as well. Any chance you have a link to the kit you used?
I’m getting a bunch of mixed ideas from local shops and since yours is proven, I appreciate taking the guesswork out.
Thank you I’m advance!
Yeah, it's correct. Izumi only makes bicycle chains for NJS (Keirin) racing now. The cert marks up the price of a part %100-400 percent, typically. It's similar to how a pressure certified shrader valve might cost $20, instead of $0.20. It doesn't help that the chain plates are blued, instead of plated. Makes the price shoot way up.Am I seeing that right? Is that chain $100?
What he said.Yeah, it's correct. Izumi only makes bicycle chains for NJS (Keirin) racing now. The cert marks up the price of a part %100-400 percent, typically. It's similar to how a pressure certified shrader valve might cost $20, instead of $0.20. It doesn't help that the chain plates are blued, instead of plated. Makes the price shoot way up.
If you want to have a fainting spell, look up how much NJS certified chainrings/sprockets cost.
You will get most of the functionality from a KMC 'B' series chain (these also have full-length bushings, which is one of the reasons Izumi/other NJS track chains are generally accepted as "better").
i appreciate it. It’s on back order. I signed up to get an email when the inventory is back up.Really simple I just used the Surly single speed kit from Jensen.
Surly Single Speed Spacer Kit | Jenson USA
www.jensonusa.com
Then ordered a number of front chain rings and rear cogs that I could mix and match. Where I live is pretty flat, so the 32:19 works pretty well.
I also switched to an Izumi Super Tough 3/32 Chain. It is expensive but it is TOUGH!
I'm one of those people and after failing to get my (carbon) Stache working properly without a tensioner, I added a Zee derailleur as a tensioner and never looked back. It's such a great bike, and I've really been enjoying it as a single.I also should mention I do have a Stache. Great bike! Mine is not SS though. Some people have had problems with Stache in SS mode. I have not tried mine in that mode but if you search around you can find some complaints particularly with the carbon version. If my rigid SS dies I will definitely switch the Stache over to give it a shot as a singlespeed. As far as your tire clearance is concerned, go for it assuming you have the aluminum version.
My trials bike destroys low quality chains and good quality chains are only part season lifespan.What he said.
For me it was worth the investment, I am 6'6" 245lbs. I tend to break lesser chains.
