1 - 4 of 4 Posts
So I decided to convert my 2014 Trek Slash8 650B to a 1x10 drivetrain. I went with Wolftooth over oneup only cause of the color choices. What I needed for the conversion was one Wolftooth 42 Cog, a Wolftooth narrow wide 104 bdc 32T chainring, RaceFace bash guard light and a Shimano XT m771 rear cassette. I needed the XT cassette because the Shimano HG62 11-36 10 speed that comes with the Slash 8 does not have a removable 17t cog on the cassette. So here we go, the images will show you the step by step install.
Step #1 The goods.
Technology Label Box Symbol
OE RaceFace ride Crank and Turbine outer chainring setup 36/22 setup.
Mode of transport Bicycle part Bicycle tire Transport Bicycle
Bicycle part Bicycle drivetrain part Bicycle chain Crankset Bicycle accessory
Rear Shimano HG62 11-36 10 speed setup.
Bicycle tire Mode of transport Bicycle part Bicycle accessory Bicycle
Bicycle part Bicycle chain Bicycles--Equipment and supplies Derailleur gears Macro photography
Bicycle tire Wheel Bicycle wheel rim Mode of transport Bicycle part
Crankshaft of and ready for tear down.
Bicycle part Bicycle drivetrain part Gear Crankset Auto part
Crankshaft torn down and ready for new parts.
Writing implement Bicycle part Hand tool Stationery Tool
RaceFace Bash guard and Wolftooth 32T Narrow Wide chainring.
Wood Hardwood Bicycle part Circle Bicycle drivetrain part
The new goods installed.
Red Hardwood Wood stain Circle Varnish
Metal Bicycle drivetrain part Circle Steel Gear
Bicycle frame Bicycle tire Bicycle part Bicycle accessory Bicycle
The front derailer & chainguide removed.
The new setup back on the bike.
Bicycle tire Bicycle frame Bicycle wheel rim Bicycle part Mode of transport
Bicycle accessory Bicycle part Bicycle Bicycles--Equipment and supplies Hybrid bicycle
Wolftooth 42T Cog.
Circle Gear Symmetry Spoke Symbol
The Wolftooth Cog and the 17T & washer removed.
Circle Gear
The Wolftooth 42T Cog installed. (Loves those industry nine Enduro Wheels).
Spoke Bicycle wheel rim Rim Red Bicycle part
The XT Cassette installed.
Spoke Bicycle part Red Rim Bicycle wheel rim
Wheel Bicycle tire Bicycle wheel rim Mode of transport Bicycle part
Now some Shimano rear derailers will need the longer set screw to push down the derailer. Without any adjustments from the OE setup I could shift from 11-36 no problem, but once it jumped into the 42T Cog, the cog and the upper derailer guide wheel were colliding. So I simply screwed the OE screw all the way in and it fixed the issues, now on some older bikes you may need the longer screw, which can be purchased separately from Wolftooth.
Bicycle accessory Bicycle part Black Carbon Silver
Overall setup on the 42T Cog. I may need to add a chain link onto the chain, seems like the angle of the rear derailer is too far forward.
Bicycle tire Wheel Bicycle wheel rim Bicycle frame Bicycle part
Closer view on the rear end.
The overall setup on the 11T.
Bicycle tire Bicycle wheel rim Wheel Bicycle part Mode of transport
Handle Bar setup. I got the new RaceFace SixC 35mm Carbon bars @ 800mm wide and the New RaceFace Atlas 35mmx50mm Stem.
Product Bicycle accessory Bicycle handlebar Bicycle part Bicycle
Close up on the left hand side setup.
Bicycle part Bicycle accessory Bicycle Red Bicycle frame
Overall view of the bike with the new 1x10 setup.
Bicycle tire Bicycle wheel Bicycle frame Tire Bicycle wheel rim
I didn't have enough time to take it out for a ride, but shifts throughout the gears smoothly all the way up on the 42T Cog. Hope to get out in the next few days for a spin on the new setup. But so far I am happy with the overall look and ride, this is one sweet bike.
Sevan
G
looks sharp all over!! I too wonder about the RD and its position when on 32/42 but if it functions well then go with it unless an issue arises.
Discussion Starter · #4 ·
On the first ride, everything actually held up very well. Chain stayed on the chainring because of the Narrow Wide and the read derailer while in the 42T cog shifted quite well. The angle of the rear derailer didn't show any issues at all. So far I am happy with the setup. Now I just need to re-adjust my derailer cable, i needed to adjust it before the conversion anyways.
1 - 4 of 4 Posts
