This is my recommendation if you can't locate a 230x62.5mm shock.I'm going to add the 2.5mm travel reducer to make it 230x62.5.
Using the travel reducer would be my suggestion as well, so you're already on the right track!Thanks for the clarification. Fox doesn't offer the DHX2 in 230x62.5mm, closest would be the 230x65 or 230x60. What would be your recommendation? I saw a video of someone using the 230x65 and 2.5mm travel reducer and didn't indicate any issues so assumed that would work. Mitch your expertise would be appreciated, thanks.
