Hello All,
I may have found a solution for the QR rear axle and be able to put in 10mm thu-bolt axle in its place.
You would obviously have to change the rear hub. I can verify that HOPE makes one with the correct 10mm end caps that would work. I have heard that DT Swiss also makes the a hub that will, but can't verify that.
The axle would be a true OEM Trek part and the serrated washers would be an anodized color and possible have an option besides black.
How many people would be honestly interested in this conversion? I know there seems to be a lot of the HT bikes that are using the 141mm BOOST rear spacing. My guess would be around $85 for the axle and washers.
