so i'm fed up with my deluxe rct reactiv from my trek remedy 9 RSL 2017 (full floater frame) so i picked up a brand new 230x60 super deluxe rct for a good price, now my project begins.
knowing little about shocks (but mechanically minded) so i'll learn along the way. is it as simple as just swapping the damper shaft over as i need the eyelet not bearing mount and also add in the blue trek spacer 10mm (will need drilling) to the super deluxe along with its grey spacer 12.7mm as well ? (thinking i'll put 3 drops of super glue to key them together but not enough so i can separate them if needed)
i have tried the super deluxe 230x60 shock in the frame deflated to see if i could just run it without travel limiting and make up custom bushings to mate the bearing mount but it bottoms on the frame plus i would be 170 in back 160 up front not ideal.
Has anyone done this let me know any hick ups i might come across as once i start my bikes out for however long it takes me and i dont wanna start till i have all the right tools like a ifp valve adapter is all i'll need ? plus calipers for ifp oil height
also rockshox 7wt oil for the ifp damper is maxima plush 7wt cst @40 30.4 @100 7.3 visco index 218
i like the look of WPL oils as there environmentally friendly
7wt 25.8 cSt 6.6 cSt 230 think thats close enough
also always wondered does a progressive frame rate vs linear effect the weight oil viscosity choice ?
