Hi all,
1. trouble:
I have some questions regarding the rear triangle sounds:
https://dl.dropboxusercontent.com/u/63396042/MOV_0127.mp4 - this is the sound that I get when I press my rear brake and try to move the wheel back-to-front.
This exact sound comes also when you press your rear brake, and let say drop your rear wheel from some height by hand. If you don't press the brake, everything is ok.
My LBS (Trek dealer where I bought the bike) said it was the rear pads from the brake that do the noise (Shimano Zee). The noise was also coming with the stock brakes (Avid Elixir 9 which have a pin where the pads go in the rear caliper).
You can imagine the noise which I get when I pull my rear brake over roots or any kind of bump where the rear suspension need to do its job.
Any one with the Fuel, or Scratch or any other FS from Trek have these creaking/cracking noises while riding ?
2. Trouble
My shock doesn't have full travel. The o-ring stops at 3-4mm before the end of the shock shaft (when you deflate it). Something is blocking it inside. Stock DRCV shock, nothing was touched. OK or not ?
The bike is 2 months old, bought new.
Thanks for all the help in advance.
1. trouble:
2. Trouble
