on a 03 stinky do you think 6 in the front and 6 in the back would ride better than 7 in the front and 6 in the back
the z-150 or junior tDeweydude said:either one should be fine
what forks are we talking about?
can someone answercrazyfreerider said:the z-150 or junior t
crazyfreerider said:can someone answer
sorry about the whining so you think i should put the extra money in for the 66 and does the vf adjustzedro said:....not if your gonna whine for help....
if you go for a 66RC, you can travel adjust is for 6-7"....same with the JrT but will require a seperate spring kit and the damping isnt nearly as nice.
the VF uses JrT internalscrazyfreerider said:sorry about the whining so you think i should put the extra money in for the 66 and does the vf adjust
so the vf isnt that goodzedro said:the VF uses JrT internals
wouldn't the 66 be too highzedro said:the VF uses JrT internals
what would happen if it is to highJBsoxB said:wouldn't the 66 be too high
why not a slider (it's lower than the 66 right?)
Slider would be certainly one of the cheaper options. I know that newish/used 04 Slider+ are going for anywhere from $200-500 online.JBsoxB said:wouldn't the 66 be too high
so i would be better of with a slider rather than a 66COmtbiker12 said:Slider would be certainly one of the cheaper options. I know that newish/used 04 Slider+ are going for anywhere from $200-500 online.
