Thanks I will look in to a tension toolmaintaining proper and consistent spoke tension will allow you to beat a set of wheels for many years with no issues...
That is the info I was looking for the abuse factor thanksPSI.
Since this is a fatbike/high volume tire, try upping your tire psi in 1 psi increments.
Rims only dent when they make contact with trails surface.
Carbon rims and too low tire PSI don't handle abuse any better than well built aluminum wheels and too low psi.
Yep this.PSI.
No. You don't need a tension tool. Well, maybe...but honestly if you want to ensure a good wheel build, you need more than just a tension tool. You need something to use for truing (like a truing stand, or maybe an old rigid fork with zip ties attached to use as guides, but this setup makes a lot of assumptions about a centered rim that a truing stand deals with), you need spoke wrenches, and a tension tool should come after all those things are addressed.Thanks I will look in to a tension tool
this is good info And it all seems like that the psiNo. You don't need a tension tool. Well, maybe...but honestly if you want to ensure a good wheel build, you need more than just a tension tool. You need something to use for truing (like a truing stand, or maybe an old rigid fork with zip ties attached to use as guides, but this setup makes a lot of assumptions about a centered rim that a truing stand deals with), you need spoke wrenches, and a tension tool should come after all those things are addressed.
AND, you then need to have an understanding of how wheel tensioning/truing works. It's not hard, but it is different from other parts on a bike and it does take attention to detail and a systematic approach.
If you're not prepared to do all that, then just take your wheels to a shop with a good reputation for good wheel work and have them go through any new (especially machine built) wheel.
But what you REALLY need to do is to pay better attention to your tire pressure. The general rule is, "if in doubt, let it out" and rim strikes are UNDENIABLY part of the "doubt" part. You do not want rim strikes. They result in flats and damaged rims. If you experience rim strikes (or pinch flats, self-steer, squirmy tires, folding sidewalls, etc), then you need to add air pressure back until you find something that gives you the best ride quality you can get without the negatives I mentioned. Fatbikes can be troublesome in this regard. I've been there. For some kinds of riding, it's possible that you'll never find a tire pressure that actually works right.
If you get carbon rims and you don't fix your tire pressures, then you're going to have some very, very expensive repairs to do.
This might be a problem, too. But after riding a fatbike year-round for awhile, one thing that's fun about it is the ability to take what I always called "the stupid line" because of all the extra traction and flotation you get from fat tires. I did get too used to fatbike line choice and everybody else's line choice so when I got a different bike, I had an adjustment period back.I can’t believe that nobody has said, Pick better lines.
Ok I’m going work on my psi my tires are 26x4Before investing in Cf rims, find out and resolve what causes the strikes. Just throwing expensive Cf rims into the ringer will just destroy them. what size of tire and rim do you have and at what pressure and system weight? how fast or aggressive do you ride?
Avoiding obstacles is good, but sometimes things just happen. So a wheel with large enough tire and pressure will be helpful. Obviously the wheel should be built well (round, tension etc.)
IMHO those insert's should be last resort. They add weight and AFAIK they only last the life of the tire and you need to re-buy with anew tire. But there may be better ones.
4.8" tires may help.Ok I’m going work on my psi my tires are 26x4
Was ridding them around 6-8 psi to get better trac going up incline but I will have go slow down my aggression on other obstacles. I was thinking that’s cf rims would take more of a beating but like some one else said it’s not a monster truck
I’m glad I posted what I did. Because I got a lot of good intel thanks!!
