I've been having problems with my tugnutt lately.Basically, my chain length is exactly so that the tugnutt doesn't fit. In the first hole, the screw is maxed out and the chain is a bit too loose and in the second hole the screw is backed out all the way and the chain is a bit too tight.
Not a big deal, I thought, until today on a climb my wheel slid forward and bent the screw into an S-shape.
Obviously I hadn't tightened the axle nut enough, and with the screw at max length it was at its weakest.
So, I'll keep the tugnutt on the non-drive side to open bottles for now. Anyone know if I can get a replacement screw? Searching on-line I'm not seeing anything. Otherwise, I guess I can try to find a long bolt at LBS or the hardware store.
Too add insult to injury, I lost my Jethro Tule on the ride. After I pulled it out of my saddle bag to re-tighten the nuts, I just dropped it in my pocket and it went missing.
Still, it was a great ride. A 12 km climb to the top of a mountain culminating in taking the wrong "trail" and spending an hour carrying our bikes while bushwhacking back up the mountainside. :thumbsup:
Regards,
Anthony
Regards,
Anthony
