Yeah, it's a great idea.
well when making a bike there is a recommended fork/tire size and that is how it would be sized, how its supposed to be ridden, wheel size? come on this is the dh/fr forumfixbikeguy said:How is this good? It is so dependant on fork length, wheel size, even tire size and has no relation to the position of the saddle. You can't measure just a frame like this, it must be a complete bike. This is not needed, there is nothing broken so why fix it?
Did you even read the press release? It says that it is also suitable for measuring XC bikes. I sit when I ride XC.scorpionsf said:well when making a bike there is a recommended fork/tire size and that is how it would be sized, how its supposed to be ridden, wheel size? come on this is the dh/fr forum
also, saddle??? how many here sit the whole time they ride? how many sit for any bit of their ride? not too many
suitable yesfixbikeguy said:Did you even read the press release? It says that it is also suitable for measuring XC bikes. I sit when I ride XC.
You are right. However it is a good way to quickly compare frames with in the manufacturer's recommended use. I have no easy way to include a relative saddle position in there though...fixbikeguy said:How is this good? It is so dependant on fork length, wheel size, even tire size and has no relation to the position of the saddle. You can't measure just a frame like this, it must be a complete bike. This is not needed, there is nothing broken so why fix it?
Reccommended fork size? Come on... how many of us are using forks that have different axle to crown heights and amount of suspension travel than what the manufacturer reccomends? Wheel size? Yeah, that would be relevant since this intended standard is supposed to be broad and therefore cover the spectrum of 29ers, 26/24 combos, 29/26 combos, etc.scorpionsf said:well when making a bike there is a recommended fork/tire size and that is how it would be sized, how its supposed to be ridden, wheel size? come on this is the dh/fr forum
You run into the same exact issues when sizing via the ETT.fixbikeguy said:How is this good? It is so dependant on fork length, wheel size, even tire size and has no relation to the position of the saddle. You can't measure just a frame like this, it must be a complete bike.
It is needed for FR and DH bikes, as TT length gives no indication of actual size, and is pretty much meaningless. A quick reread of the article will tell you that.fixbikeguy said:This is not needed, there is nothing broken so why fix it?
Weird...I always thought that the "saddle" was that thing that prevented your butt from getting sucked into the rear wheel when your feet blow off the pedals. I didn't realize people actually "sat" on them...fixbikeguy said:Did you even read the press release? It says that it is also suitable for measuring XC bikes. I sit when I ride XC.
