I ordered a leftover V1 transam from transition about 3 weeks ago, and when it came, it was the wrong size. It took a few days, but I was finally able to convince them that it was indeed a medium frame, and not the small I ordered. Well, they were out of the orange, so I had to settle for a white frame. That's fine, I'm not that picky. Now 3 weeks after placing my initial order, I finally get the right size frame, only to find that on the machined 45 degree bearing surface in the head tube is a glob of what I'm guessing is the electro deposited coating. It is quite rough and "bubbly" and it has been machined along with the steel to form that 45 deg. angle for the headset bearing. There's also a chunk of paint missing right on the front of the head tube where it looks like it didn't stick to yet another glob of the ED coating. Not too happy about that either.
So, to make a long story longer, I've got two questions:
Has anybody else had the glob of stuff in the headset problem with their transam? If yes, did it affect the seating of the headset bearings at all?
There's no way the coating material is as hard as cromo steel, and I'm worried that the deposited material will wear (or worse, chip away) faster than the steel, and leave an uneven bearing surface for me to deal with.
Pictures forthcoming...
