Its most likely the DU bushings in the rear shock. Pull the rear shock out and inspect the bushings and shock eyelet spacers. You will have to pull the crank to get at the lower shock bolt. Then grease the bushings/spacers. I like to use an automotive Moly grease as it stays put and lubes longer than just about anything else.
