1 - 20 of 2260 Posts
peakprowler said:
floorguy .. how does the X0 handle with the 36 & any chance you could measure the bottom bracket height?
I'll let you know, first ride is tomorrow (sun). As far as the BB, mine measures right at 14".:thumbsup:
Johny Sokko!
Finally have my Trance X built the way I want it.
Changes made that stiffened up the bike for a Clydesdale/Trail Demon.
Coil Fork: 2007 Manitou Minute Elite 110-140mm Thru-Axle (much stiffer and stronger than the Fox and only slightly heavier).
Thomson Stem and Seatpost!
Tires: 2.35 Nevegal Up front and 2.1 Nevegal DTC with sidewall protection (SWS) rear.
Wheels: Crossmax XL Wheelset
Seat: Rocket V
Brakes: 7" rotors front and rear
Handle Bars: 2008 Race Face Atlas with Ergon grips
Cassette: SRAM PG-990
Pedals: Time Atac XS
Weight: 28.5" lbs.
Here’s my 2008 Giant Trance X2 with 08 XT shifters and FD, SDG Bel-Air saddle and RACE FACE grips-shortly to be new Ritchey WCS foam grips.
Here is my TRANCE X0 M.
Stock except for the X0 derailleur and X9 shifters.
<a href="https://picasaweb.google.com/danielcarbonari/GiantTranceX0/photo#5141697375304805650"><img src="https://lh5.google.com/danielcarbonari/R1r6hV2Z7RI/AAAAAAAAAcw/VtI8q3XcD_0/s800/TRANCE_X0_03.jpg" /></a>
<a href="https://picasaweb.google.com/danielcarbonari/GiantTranceX0/photo#5141697375304805634"><img src="https://lh5.google.com/danielcarbonari/R1r6hV2Z7QI/AAAAAAAAAco/nx4sq4PtWFE/s800/TRANCE_X0_02.jpg" /></a>
Yeti SB5, Grove Bike Co R.A.D
Trance X1. It weighs whatever it weighs...
It's got an SDG Bel Air saddle now, but the rest is stock.
banjo plunker, wrench
For you guys that already have a Trance X...is a 2.35 the largest tire you can put on the rear. I'm looking at making one clydesdale safe...yet lighter than 32lbs.
I've built up several at the shop I work at, in and around 28 to 30lbs. I used a regular drop-out fork on one of these, an XL, and another shop custom build with a 55ATA and all XT with the FR wheelset but used Nevegal tubeless (in a medium frameset, it weighed in at 28.5lbs). The bike close to 30lbs., was an XL with Fox 32 float, mostly XT, with Stylo crankset, and Mavic 717/XT hubset with 2.1 Nevegals (regular not tubeless).
So with say a set of Dee Traks wheels...could I run a 2.35 in the back? I haven't tried it out yet. I'm planning on getting the Trance X2 (I like the black frame) and using either a 55TST-R, or Fox 36 Vanilla R. I'm probably going to run a 2.5 in the front. Hard to break FR habits...LOL Thanks in advance!
floorguy724 said:
Wow! nice bikes guys! Here's mine finally finished. Weight is at 26 lbs. even!
floorguy724, can you measure the BB height of your bike? I am interested to know what the BB height is with a Pike at 140mm.
Thanks.
2010 Glory custom FR
all of them look much better than on giant's web-site or in the catalogue :)
Stoner's Trance is my favorite, so far :)
My T X 0 size S will come in middle Feb. I will rebuild it a bit, but it will be a surprise ;)
Thanks.
With the Pike the bb comes in at 13". It was right around 14" with the Fox 36 Van on it.
Originally posted by: swaneedawg For you guys that already have a Trance X...is a 2.35 the largest tire you can put on the rear. I'm looking at making one clydesdale safe...yet lighter than 32lbs.
I have a 2.35 Nevegal on the back of my Trance X2 and it fits fine. About an 1/8" clearance on each side. :thumbsup:
First try at downloading a picture. Stock except for Wellgo MG-1 pedals, Oury grips, 2.35 Nevegals (front and back) and Thomson setback seatpost. Revised X2.JPG
Johny Sokko!
Senor Frango,
Thank you very much for the kind words. Been riding a Trance and Reign since 2005 and this bike set-up is the result of what works best for this bike. I liked the Fox but I don't like Air shocks up front, a good smooth dialed in coil fork can never be beat! The Fox seemed to light to track well for me when hitting high speed rocky turns and rock gardens (I ride steep Los Angeles mountains).
I almost put my Atlas cranks on but decided to give the Dues a shot. This set-up is the stiffest trail bike you ever ride and it tracks like it was glued to ground.
Trance X... If you don't have one... get one!
