1 - 5 of 5 Posts
I know a chain guide is not the most ideal set up on a Trance X considering its a XC bike. The Trance is my only current bike and has become my XC/AM combo and I would like to outfit it with a chain guide. I have removed the the big front chain ring and bought e13 sts thinking I could modify the STS by cutting off the top part off the backplate (since I'm keeping the front derailer). Everything seems to ok until I try to fit the drive side back onto the BB. It seems like the backplate is too thick, I have tried removing the spacers on the BB but still will not work. I cant get any threads on the 8 mm bolt to catch on the spline. Should I just give up on this set up? Any other suggestions or any other proven set ups that have worked for other members?
Former Ninja
Hello,
The STS is actually designed as a single ring guide only...as it sounds like you have a Trance X with a threaded european bottom bracket, I would suggest looking at the Heim2 in Bottom Bracket mount config. This will mount up considerably better (and easier) than the older style STS. The Heim2 also comes as a guide-only assembly, so you can use your current bashguard.
https://www.e13components.com/product_heim2.html
Cheers,
philip @ theHive/e*thirteen
Discussion Starter · #4 ·
Look like the Blackspire Stinger might be my best bet considering the price since I have already spent money on the e13 sts. I should at least be able to use the E13 bashguard and run the Stinger as the actual chian guide.
1 - 5 of 5 Posts
