1 - 20 of 48 Posts
I know there is the Trance official thread, with some great info in there, and perhaps this should go in it. I thought it would be a great idea to have a thread dedicated specifically to having everyone post detailed specs of their bikes & photos as an option as well (preferably links so that the pages load quickly). I would like to see a Reign Setup database started as well. Would make for easy reference at any time.
I saw something very similar a while ago in one of the other manufacturers forums and thought it was a great idea.
Something like this: - Add your own and feel free to highlight any upgrades over stock like I've done.
MODEL: Trance 3 - Australian
COLOUR: Silver
FORK: RS Tora 318 Solo Air 130mm travel.
SHOCK: Fox Float R Propedal
WHEELS:
FRON HUB: Formula Disc
REAR HUB: Shimano M475 9sp disc
SPOKES: 14/15G Stainless Black
RIMS: Mavic XM117 32H
F TIRE: Maxxis Advantage 2.4 wire
R TIRE: Syncros Point N Cute 3 2.5
STEM: Syncros FR 50mm
BAR: Race Face Deus XC Lo Rise 1" rise 31.8 dia 25" wide
POST: Thomson Elite inline 30.9 x 367mm
GRIPS: OURY
SADDLE: Specialized Avatar Gel 155mm
HEADSET: FSA Ahead Integrated
F BRAKE: Shimano XT
R BRAKE: Shimano XT
LEVERS: Shimano XT
CRANKSET: Race Face Evolve XC X-Type 32T with a 32T EThirteen Bashie
PEDALS: DMR V12 Mag Platforms
CHAIN: Shimano Deore 9spd
FREHWEEL: Sram PG950 11-34T
F DERAILLEUR: None
R DERAILLEUR: Sram X7 Trigger
F SHIFTER: None
R SHIFTER: Sram X7
OTHER: EThirteen Bashring & Envy Inner Ring
WEIGHT: 14kg on my bathroom scale
ADDITIONAL INFO (Any Extra comments / accessories):
Rider - Female 169cm tall & about 60kg.
Style of riding: Just out on the trail, would class it mostly as XC but beginning to get more adventourous with small jumps & drops these days. Woohoo
Converted to a 1x9er with ethirteen bashie & envy ring protector running on the inside to keep the chain from jumping.
Also took out the tora all travel spacer during the service. The bike rocks with 130mm of travel feels more plush & comfy now. I love it!
Don't forget you can edit your specs as they change down the track.
Johny Sokko!
MODEL: 2005 Trance 4 - USA
COLOR: Blue
FORK: 2006 Manitou :02 100~130mm
SHOCK: Manitou Swinger 3-way
WHEELS: CrossMax Enduros
FRONT HUB:
REAR HUB:
SPOKES:
RIMS:
F TIRE: Panaracer Fire XC Pro 2.1 Kevlar bead
R TIRE: Panaracer Fire XC Pro 2.1 Kevlar bead
STEM: Thomson Elite 110mm x 5deg x 25.4"
BAR: Race Face Evolve XC
POST: Thomson Elite Layback
GRIPS: ODI Ruffian Lock On
SADDLE: WTB Pure V
F BRAKE: Hayes 9 XC / 7" Rotor
R BRAKE: Hayes 9 XC / 7" Rotor
LEVERS: Hayes
PEDALS: Time Atac
CHAIN: Shimano XTR 7701
CASSETTE: Sram PG-990 11-34T (Red Spindle)
F DERAILLEUR: Shimano XT
R DERAILLEUR: Shimano XT
F SHIFTER: Shimano XT
R SHIFTER: Shimano XT
WEIGHT: 28.5lbs.
Here's Mine
My Trance was born a Trance 3 US model, but I have changed nearly everything and now even it's mother wouldn't recognize it.
MODEL: Trance 3 - US
COLOR: Silver
FORK: Fox Float RLC 130mm.
WHEELS: Crossmax Enduros
F TIRE: Panaracer Fire XC Pro 2.1 Japanese version
R TIRE: Panaracer Fire XC Pro 2.1 Japanese version
TUBES: Panaracer Poly (Green ones)
SKEWERS: Sette TI
STEM: Sette 10 degree 110mm
BAR: Easton EC-70 CNT
POST: Thomson Elite 30.9 x 367mm
GRIPS: Lizard Skin lockon
SADDLE: WTB Rocket V Stealth TI rails
F BRAKE: Hayes Nine 7" rotor
R BRAKE: Hayes Nine 6" rotor
PADS: Hayes semi-metallic
CRANKSET: Race Face Deus XC X-Type 22 x 32 x 44T
PEDALS: Xpedo Al/TI
CHAIN: Shimano XTR CN-7701
CASSETTE: Shiimano XT 11-34T
F DERAILLEUR: XTR
R DERAILLEUR: XTR
F SHIFTER: Shimano Deore
R SHIFTER: Shimano Deore
CABLES: Avid Flak Jacket
WEIGHT: 28.0 lbs. with Ultimate Digital
RIDER WT: 190 LBS RTR
SUSPENSION SETUP: All "click" adjustments are clicks from full in (CW) Fork 75psi, 8 clicks compression, 9 clicks rebound, lockout 7 clicks; Shock 175psi, 6 rebound; tires 35 psi
ADDITIONAL INFO: Wireless Sports Instruments computer/HRM Frame is stripped and anodized, saved 6 oz frame weight 6.3
Well personally I think it's a pretty good idea, however I think we should keep the pics out or very small to make sure it loads fast. Anyway here's mine :D
COLOUR: Silver
FORK: RS REBA SL
SHOCK: Fox Float R
WHEELS:
FRONT HUB: Shimano XT M756 DIsc
REAR HUB: Shimano XT M756 DIsc
SPOKES: 15G Stainless Silver
RIMS: Mavic XM321 32H
F TIRE: KENDA Nevegal Stick-E 2.1"
R TIRE: KENDA Nevegal DTC 1.95"
STEM: Bontrager RACELIGHT 31.8
BAR: Bontrager RACELIGHT 31.8
POST: Easton EA30
GRIPS: ERGON M2 MAG
SADDLE: WTB RocketV
HEADSET: FSA OEM
F BRAKE: HOPE Mono MIni
R BRAKE: HOPE Mono MIni
LEVERS: HOPE Mini Lever
CRANKSET: Shimano XT HollowTech2 175mm
PEDALS: Shimano M520
CHAIN: Shimano CN7701/XTR 9spd
FREEHUB: Shimano XT 34 -11
F DERAILLEUR: Shimano Deore XT M750
R DERAILLEUR: Shimano Deore XT M760 Medium Cage
F SHIFTER: Shimano DeoreXT RapidFire
R SHIFTER: Shimano DeoreXT RapidFire
BEARINGS: EnduroForkSeals MAX type
WEIGHT: 30+/-lbs on my digital bathroom scale
She was sub *30lbs till I put on the ERGON grips, but the weight they add is more than made up for by the comfort they provide. Future upgrades include a set of XT trigger shifters which are on route and a set of Hope Pro2 hubs laced to some DT 4.1 rims which should drop at least 1lb off the weight. Upgrades are in RED and the ones that made the most significance to the bike/ride and also bolded.
- Basically now it's a T2+ ;)
Additional Info - I'm 6'2"+ and weigh around 170-175lbs suspension setup is REBA set @ 115mm travel, Neg. PSI=55-65, Pos. PSI = 90 -100, FloatR PSI = 190-210lbs
* weight includes pedals
**9_28_2006 - Updated to show new XT Shifters :D now all XT drive train
MODEL: '05 Trance 3 - USA
COLOR: Silver
FORK: '06 RS Reba Race, 115mm Travel w/ PopLoc Adjust, Enduro Seals
SHOCK: PUSHed Fox Float R Propedal
REAR SUSPENSION BEARINGS: Enduro Max
FRONT HUB: Hope Pro II
REAR HUB: Hope Pro II
SPOKES: DT Swiss SuperComp
RIMS: DT Swiss 4.2d, 32 Hole
FRONT TIRE: Panaracer Fire XC Pro 2.1, 127 TPI
REAR TIRE: Panaracer Fire XC Pro 2.1, 127 TPI
FRONT WINTER TIRE: Nokian Hakka WXC 300 2.1, Studded
REAR WINTER TIRE: Nokian Hakka WXC 300 2.1, Studded
TUBES: Maxxis Ultralight
STEM: Ritchy Logic Pro, 100mm x 5 degree
BAR: '06 Easton MonkeyLite XC, Low Rise
POST: Thomson Elite Setback, 367mm x 30.9mm
SADDLE: WTB Shadow V Team
HEADSET: FSA Orbit Z, Zero Stack
FRONT BRAKE: '07 Avid Juicy 7
REAR BRAKE: '07 Avid Juicy 7
LEVERS: Avid
CRANKSET: Race Face Deus XC, 22/32/44T
BOTTOM BRACKET: Race Face X-Type
PEDALS: Shimano PD-540
CHAIN: SRAM PC-991
CASSETTE: '07 SRAM PG990 11-34T
FRONT DERAILLEUR: '07 SRAM X7, Low clamp
* Interference issue with rear triangle see http://forums.mtbr.com/showthread.php?p=2338652#poststop
REAR DERAILLEUR: '07 SRAM X9, Long cage
FRONT SHIFTER: '07 SRAM X9
REAR SHIFTER: '07 SRAM X9
WEIGHT: 27.75 lbs / 12.59 kg (Ultimate Alpine Digital Scale)
ADDITIONAL INFO:
Front Suspension Setup (160lb): 115mm Travel, + Air: 85psi; - Air: 95psi, Comp. Damp: 50%; Floodgate: 1~2 turns CW (open)
Rear Suspension Setup (160lb): + Air: 160psi
Navigation / Computer: Garmin eTrex Legend GPS
Lighting: Trail Tech MR11 HID Flood, Helmet Mounted
Future Upgrades: ??
I ride bikes
MODEL: Trance 1 - 2006 USA
COLOR: Pearl White
FORK: Fox F100RL
SHOCK: Fox Float RP3 w/ Carbon Shock Guard
WHEELS:
FRONT WHEEL: Mavic XC717, Shimano XT Centerlock, DT Swiss 14/15ga spokes
REAR WHEEL: Mavic XC717, Shimano XT Centerlock, DT Swiss 14/15ga spokes
F TIRE: WTB Mutano Raptor 2.4
R TIRE: WTB Mutano Raptor 2.4
COCKPIT:
STEM: Race Face Deus XC
BAR: Easton Monkeylite XC Carbon Low Rise
SEATPOST: Race Face Deus XC, 350x30.9
GRIPS: Oury
SADDLE: Forte Team - Titanium Rails
BRAKES:
F BRAKE: Shimano XTR Hydraulic
R BRAKE: Shimano XTR Hydraulic
LEVERS: Shimano XT Hydraulic
ROTORS: Shimano Centerlock 160mm
DRIVETRAIN:
CRANKSET: Race Face Deus LP X-Type 22/32/44
PEDALS: Crank Brothers Eggbeater C
CHAIN: Shimano HG73
FREHWEEL: Sram PG990 12-34
R DERAILLEUR: Shimano XTR
SHIFTERS: Shimano XT
WEIGHT: not sure anymore
ACCESSORIES:
Cateye Wireless Computer
ADDITIONAL INFO (Any Extra comments / accessories): This bike rides like a dream - it's absolutely unstoppable on the trails. Everything on the bike is a balance between light weight, function, strength, an durability. The stock Crossmax SL's had to go - my new wheelset is only 250 grams heavier and 1/4 the price. I like the big fat 2.4 Mutano Raptors a lot more than the Pythons.
Ok, I'll bite. As you'll see by the specs I bought the complete bike so I could build off the frame with parts that I already owned.
COLOUR: Blue
FORK: Fox 36 TALAS, set between 110mm and 130mm
SHOCK: Push'd Fox Float R Propedal
WHEELS (summer): Mavic CrossMax XLs
TIRES (summer): 2.35" Kenda Nevegal single ply, xc tubes
WHEELS (winter): Hadley hubs laced to Mavic 823s *
TIRES (winter): Michelin 2.2" Comp 16 / 24, dh tires tubeless (f/r) *
STEM: Easton Vice, 65mm 25.4
BAR: RaceFace Deus XC Low Rise
POST: stock Easton post
GRIPS: Odi Ruffian, shortys
F BRAKE: Hayes El Camino, 6" rotor
R BRAKE: Hayes El Camino, 6" rotor
CRANKSET: Shimano XT, Hollowtech II, 44, 32, 22
PEDALS: Crank Bros EggBeaters C // Crank Bros Candy SL
CHAIN: SRAM 991
CASSETTE: SRAM 990 11-32
F DERAILLEUR: Shimano LX
R DERAILLEUR: SRAM X0
SHIFTERS: SRAM X0 twisters
WEIGHT: 30.25lbs (with Alpine Digital scale)
WEIGHT (winter): 33.75lbs
ADDITIONAL NOTES: I run heavy dh wheels in the winter! With those hoops, I can run lower pressures for better grip in wet conditions. Could get the bike lighter, but I don't think the tradeoffs (cost, weight, strength) would be worth it to me.
Edit: This is a cool for seeing how many different types of builds people can put together around the Trance frameset...
jimmyd
This is my version that I spin around the bush here
MODEL: 2006 Trance 1 (Australian Version)
COLOUR: White
FORK: Rock Shox REBA World Cup
SHOCK: RP3
WHEELS: Mavic CrossMax SL disc
TIRES: Maxxis CrossMark 2.1 Tubeless
STEM: Thomson X4 110mm x 6 degree
BAR: RaceFace Next Carbon Low Riser
POST: Easton EC70
GRIPS: Odi Ruffian
SADDLE: Giant Carbon Gel
F BRAKE: Avid juicy 5, 6" rotor
R BRAKE: Avid juicy 5, 6" rotor
PEDALS: Shimano XTR 2007
CHAIN: SRAM Hollowpin / Shimano XTR
SHIFTERS: SRAM X0
WEIGHT: 27.5lbs (bathroom scales)
Future upgrades on the cards: Brakes - not unhappy with the Juicy 5, but some Avid Ultimates might be nice. Different tires for the rougher, looser stuff.
ADDITIONAL NOTES: Set up now has been running for about a month and is dialled in nicely for me. The tubeless tires have been a revelation and just a dream. The Thomson stem and 31.8 bar setup inspires confidence. I definitely like the 4 bolt attachment rather than the 2 bolt that the original Easton stem had (always creaked).
I like how the COG is very low in the frame, so the extra frame weight is hidden nicely. The Australian version for 2006 was a sweet setup especially with the wheels.
MODEL: Trance 2 - Europe
COLOUR: Black
FORK: Pace RC41 XCAM
SHOCK: Fox Float R
WHEELS:
FRONT HUB: DTSwiss 240s
REAR HUB: DTSwiss 240s
SPOKES: DTSwiss Revolution and Competition
RIMS: DTSwiss XR4.1d
F TIRE: Schwalbe Nobby Nic 2.1
R TIRE: Schwalbe Nobby Nic 2.1
STEM: Raceface Evolve XC
BAR: Race Face Evolve XC Lowrise
POST: Race Face Evolve XC and Salsa Flip Lock
GRIPS: Syntace Moto
SADDLE: Selle Italia SLR
HEADSET: FSA OEM
F BRAKE: Hayes Nine 7" rotor and Koolstop
R BRAKE: Hayes Nine 6" rotor and Koolstop
LEVERS: Hayes Nine (planned upgrade: Hayes CNC levers)
PEDALS: Time ATAC Z (planned upgrade: still locking for optimal weight/function pedals :confused: )
CHAIN: KMC X-10SL
FREEHUB: SRAM PG970 (planned upgrade: Shimano XTR)
F DERAILLEUR: Shimano Deore XT M750 (planned upgrade: Shimano XTR)
R DERAILLEUR: SRAM X.9 long cage
F SHIFTER: SRAM X.0 Gripshift
R SHIFTER: SRAM X.0 Gripshift
BEARINGS: Originals (until they need to be changed :D )
WEIGHT: 27+/-lbs (12.3kg) including pedals
Pictures and more (most in german): http://giant-trance.cosimo.ch
bikerbert
05 Trance 4 with:
RaceFace Deus: Stem, Seatpost, Bar
RaceFace Evolve XC Cranks
SRAM X9 Shifters
X9 Rear der
LX Front der
XT Chain
Mavic CrossRide wheelset
RockShock Duke XC Fork
Avid Single Digit 7 Levers
Avid Single Digit 7 Brakes with Kool Stop Salmon Pads
**Had BB7's and tried the SD7's to experiment. Two months later, I'm lovin' the SD 7's!
Maxxis ADvantage 2.1's
Ergo Race Grips
Cateye Astrale 8 computer
THE chainstay guard
Saddle: WTB Rocket V Race
I'm looking to get X.O twisters and rear der at some point. Maybe some phatty ceramic Mavics because I don't ride on wet/muddy trails all that much. I'd like to upgrade the shock as well. Maybe the RP3.
MODEL: 07' Trance frame set
COLOR: Black & Gray
FORK: Fox 100 RL
SHOCK: Fox RP23
WHEELS: Mavic Crossmax SL
FRONT HUB: Mavic Crossmax SL
REAR HUB: Mavic Crossmax SL
SPOKES: Mavic Crossmax SL
RIMS: Mavic Crossmax SL
F TIRE: WTB Mutano Raptor Rce 2.4"
R TIRE: Schwalbe Jimmy 2.1"
STEM: Race Face Deus XC 90mm
BAR: Easton Monkey Lite SL
POST: Easton EC 90
GRIPS: Ritchey WCS Foam Grip
SADDLE: Sette Italia SLR
HEADSET: FSA OEM
F BRAKE: Shimano XT Hyd.
R BRAKE: Shimano XT Hyd.
LEVERS: Shimano Hyd.
CRANKSET: FSA K-Force Carbon 175
PEDALS: Eggbeaters 2 Ti
CHAIN: Wipperman (Gold)
R DERAILLEUR: Sram XO Med cage
F SHIFTER: Sram XO Twist
R SHIFTER: Sram XO Twist
WEIGHT: 26.5lbs.
Here is my '07 Trance
I keep with the format below. The frame is an '07 (Gray/Black) built up with parts from my Chameleon.
MODEL: Trance Frameset - '07 - US
COLOUR: Gray/Black
FORK: RS Pike Race 95 mm - 140 mm.
SHOCK: Fox Float RP23
WHEELS:
FRON HUB: Hadley 20 mm Thru Axle
RIMS: Sun Rhyno Lite
F TIRE: Kenda Nevagal 2.35
R TIRE: Kenda Nevagal 2.35
STEM: Thomson X4 90mmx 5 deg
BAR: Easton MonkeyLite
GRIPS: Odi Ruffian Lock On
F BRAKE: Magura FR 8"
R BRAKE: Magura FR 7"
LEVERS: Magura
PEDALS: Time Alum
CHAIN: Shimano LX 9spd
FREHWEEL: XT
F DERAILLEUR: Deore
R DERAILLEUR: XT
WEIGHT: More than my Chameleon
Rider - Male 5'11" about 187 lbs.
Style of riding: Just about everything but DH and jumps. I don't do jumps. Honestly, mostly Eastern US singletrack.
Hope this work.
REV
Funny how all these bikes keep evolving. They start all the same and within a year they are all different.
MODEL: 2005 Trance 3 - US
COLOUR: Silver
FORK:RS Reba Race
SHOCK: Fox Float R
WHEELS:
FRONT HUB: Shimano XT M765 Disc
REAR HUB: Shimano XT M765 DIsc
SPOKES: 14/15G DT Swiss Black
RIMS: Mavic XM819 32H
F TIRE: Kenda Nevegal UST 2.1
R TIRE: Kenda Nevegal UST 2.1
STEM: Easton EA50 OE
BAR: Easton EA50 OE
POST: Easton EA50 OE
GRIPS: Performance Cheapo
SADDLE: WTB RocketV
HEADSET: FSA OE
F BRAKE: Shimano XT 765
R BRAKE: Shimano XT 765
LEVERS: Shimano XT 756
CRANKSET: Shimano XT, 22/32/44
PEDALS: Crank Bros Candy SL
CHAIN: SRAM PC 971
FREEHUB: SRAM PG950 11-34T, 9 speed OE
F DERAILLEUR: Shimano LX OE
R DERAILLEUR: Shimano XT 760
F SHIFTER: Shimano XT RapidFire
R SHIFTER: Shimano XT RapidFire
MODEL: Trance 4 - '05/06 - Europe
COLOUR: Blue/Grey
FORK: RS Revelation 426 Dual Air set at 115mm
WHEELS:
FRONT HUB: Hope XC black
REAR HUB: Hope XC black
SPOKES: DT Stainless silver
RIMS: Mavic F519 (XM719) silver
F TIRE: Bontrager Jones ACX 2.2
R TIRE: Bontrager Jones ACX 2.2
STEM: Post Moderne SMICA Pro 90mm 5deg
BAR: X-lite XC2 Riser
POST: Post Moderne SMICA Pro 30.9mm 350mm
GRIPS: Halfords (Velo?) Lock On grips
SADDLE: WTB Rocket V Race
HEADSET: FSA Ahead Semi Integrated
F BRAKE: Shimano LX Hydraulic 180mm
R BRAKE: Shimano LX Hydraulic 160mm
LEVERS: Shimano
CRANKSET: Shimano LX Octalink
BOTTOM BRACKET: Shimano ES51
PEDALS: Ritchey Logic Comp
CHAIN: SRAM PG 951
FREEWHEEL: Sram PG 970
F SHIFTER: Shimano LX
R SHIFTER: Shimano LX
WEIGHT: Not weighed but I guess at around 28.5lb ish)
Rider - Male 5'11.5" about 190 lbs.
MODEL: Trance Frameset - '07 - UK
COLOUR: Blue/Grey
FORK: RS Reba World Cup 100mm
WHEELS:
FRONT HUB: Formula
REAR HUB: Formula
RIMS: Alex DP-17
STEM: ITM 90mm 6 degrees
POST: New Giant Comp alu 30.9 x 350mm
GRIPS: ODI Yeti Hard Core Grip
F BRAKE: Giant MPH 3 160mm
R BRAKE: Giant MPH 3160mm
LEVERS: Giant MPH 3
CRANKSET: FSA Afterburner
BOTTOM BRACKET: FSA Integrated MegaExo
PEDALS: Crank Brothers Candy CL Pedals
CHAIN: Shimano
FREEWHEEL: Shimano
WEIGHT: Not sure, think about 27lb
Total rebuilding
MODEL: Trance 4, 2005 - EU
COLOR: Slate grey
FORK: Marzocchi Marathon SL 105, 2004
SHOCK: Fox Float R
WHEELS: SH XTR (M950) / Ritchey SGSS 1,8 / Ritchey Pro Rock+OCR
F TIRE: Conti Gravity Pro 2.3
R TIRE: Conti Vapor wire 2.1
TUBES: Conti Supersonic
STEM: Ritchey Pro 130mm, 6 deg.
BAR: Ritchey Prolite 560mm
POST: Ritchey WCS 30.9 x 350mm
GRIPS: Ritchey WCS 96mm
SADDLE: Fi´zi:k Gobi Ti, black
HEADSET: OEM, Integrated
BRAKES: Avid SD SL, Ritchey Pro speedblast
CRANKSET: Ritchey Logic Compact 29/44T, 175mm
BB: SH UN72, 107mm
PEDALS: Time ATAC XS Carbon
CHAIN: Sram PC971
CASSETTE: Sram PG980 11-34T
F DERAILLEUR: SH FD-M570
R DERAILLEUR: Sram X.9 medium cage
SHIFTERS: Sram Twist X.O shorty
BAR ENDS: Coda Paquito
WEIGHT: 12,9kg
RIDER: 175cm, 80kg ready to go
SUSPENSION SETUP: Marz + 33PSI, - 90PSI, Fox 200PSI
MODEL: Trance 0, 2007 Aussie
COLOR: Scotchbrite / blue
FORK: Fox, F100 rlc 2007
SHOCK: Fox Float RP23 2007
WHEELS: Mavic crossmax st ust 2007
F TIRE: maxxis crossmark 2.1 folding
R TIRE: maxxis crossmark 2.1 folding
STEM, BAR, POST: Race face dues xc
GRIPS: giant lock on
SADDLE: specialized rival
BRAKES: Avid Juicy 7 2007
CRANKSET: Raceface dues xc
PEDALS: Shimano
F DERAILLEUR: shimano xt 2007
R DERAILLEUR: shimano xtr 2007
SHIFTERS: shimano xt 2007
WEIGHT: 11 kg (bathroom scales, Im guessing a few more though)
MODEL: Trance 1 - USA
COLOUR: Blue
FORK: 03 Marz Z1 fr .
SHOCK: Fox RP3 Propedal
WHEELS:
XT Rhynolites
F TIRE: IRC Trailbear 2.25
R TIRE: IRC Trailbear 2.25
STEM: Weyless Dh
BAR: Profile tenacious D 28" wide 2" rise
POST: raceface Carbon
GRIPS: Odi Yeti
SADDLE: Bontrager
F BRAKE: Shimano Deore hydro
R BRAKE: Shimano Deor hydro
LEVERS: Shimano
CRANKSET: XT w XTR spider/rings 24 x 34 x 46T
PEDALS: Shimano Pedals
CHAIN: SRAM
FREHWEEL: Shimano XT 11-34T
WEIGHT: 34 lbs
Bought as a used frameset and built up with all parts from older model Heckler. Heavy but I am not concerned with the weight. Slack because I like it that way
Rider - male 160 lbs
Style of riding: Aggro XC/ AM
enjoy the view
MODEL: Trance 1 Frameset - '05
COLOUR: Blue
FORK: 07 Fox F100RLC
WHEELS:
FRONT HUB: XT
REAR HUB: XT
SPOKES: DT black
RIMS: Mavic xc717 black
F TIRE: kenda nevegal 2.35
R TIRE: kenda nevegal 2.35
STEM: thomson elite 100 mm, 6 deg rise 25.4 dia
BAR: easton monkeylite
POST: thomson elite 30.9 longest length
GRIPS: odi rogue lock-ons
F BRAKE: avid bb7
R BRAKE: avid bb7
LEVERS: avid
CRANKSET: Shimano XT hollowtechII
BOTTOM BRACKET: XT external bb
PEDALS: crabkbros candy sl black
CHAIN: LX 9 spd chain
FREEWHEEL: XT 9 spd cassette
WEIGHT: Not weighed but I guess at around 30 lb-ish)
Rider - Male 6'1 230 lbs.[/QUOTE]
just replaced max bearings in 2 pivots, hopefully i'll upgrade to avid juicy7's or hayes el camino's next year.
MODEL: Trance 05 Frame
COLOUR: Blue
FORK: RS Revelation dual air with poplock.
SHOCK: Fox rp3
WHEELS:
FRON HUB: Hope proII
REAR HUB: Hope proII
SPOKES: DT comp black
RIMS: DT ex5.1
F TIRE: varies
R TIRE: varies
STEM: Thomson 100mm 5 rise
BAR: Easton EA70 cut to 26 1/2 inch
POST: Thomson Elite inline 30.9 x 410mm (cut down)
SADDLE: SDG bel air blue cammo limited edition
F BRAKE: Avid juicy 7 185mm 2007
R BRAKE: Avid juicy 7 160mm 2007
LEVERS: Avid
CRANKSET: Race Face Deus XC silver 170mm 22/32/44
PEDALS: DMR V12 Mag
CHAIN: Sram pc 99
FREHWEEL: Shimano XT 11-32
F DERAILLEUR: Shimano xt top swing low clearance
R DERAILLEUR: Sram x9 medium cage 2007
F SHIFTER: Sram x9 2007
R SHIFTER: Sram X9 2007
WEIGHT: unknown
i like the high BB and added stability from the 130mm fork
im a 6 ft rider, strictly speaking i should be on a 20inch frame, but i went for 18 to keep the reach short so when i drop the saddle on the decents the bike is alot more whippy - so ive got alot of post showing for general riding.
1 - 20 of 48 Posts
