What You'll Need.
First up you need to totally disassemble the rear suspension of your bike, for this you'll need 2-5mm Alan Keys and 2 - 8mm Alan Keys. Remove the Release the Rear Derailer cable (it is also advisable to remove the actual Rear Derailer so it doesn't get in the way or add additional weight to the rear triangle while working with it) Rear Brake and cable, chain, rear wheel (you can do this if you flip the bike upsided down on the saddle and handlebar) and crankset and that's it for what needs to come off components wise.
Next release all the air from the rear shock, then using the 5 & 8mm alan keys remove all the suspension bolts - it is easier to use the screw driver adapter bit and a socket wrench w/ 5mm and 8mm alan keys so you don't have to remember which way tightens and which slackens the bolts and wrisk snapping them by accidentally tightening them.
Once you have the rear triangle off and the two linkages clean them up from grease etc with a rag so you can properly see what you're doing. Remove the contact washers on the inside of the bearings on both the linkages and rear suspension triangle - clean them and put somewhere safe.
- Hammer
- Weight or other solid object with sufficient size hole
- 10-15mm & 7mm threaded rod or very long threaded bolts w/ Wing-Nuts or normal Nuts
- Washers to fit the threaded rod/bolts and just smaller than the OD of the bearings
- 9mm Socket and Screw Driver Bit socket
