1 - 17 of 17 Posts
My LBS has both, and I am interested in the trance. Just wondering if the extra 500$ for the Carbon frame is worth it (I am assuming it weighs less)
Also, any thoughts on the
Sram vs shimano DT
Avid vs shimano Brakes
RS vs Fox set up
are the components on the advanced a good upgrade as well? Same/similar wheels :(
cheers
I'm in the same situation.
Not really, most of the Advanced 2's components are downgrades from the Trance1, so you're mostly paying for the carbon front triangle, not sure whether the Advanced 2's Sektor fork is as good or better than the Talas CTD on the Trance1.
I think there is less than 1/2 lb difference in weight so it would come down to ride stiffness and componetry. IMHO the alloy and carbon frames look similar in tube dimensions so I suspect the carbon version might give quite a nudge to frame stiffness?
IMHO both of the fork shock options on either would be an immediate upgrade for me. Both are price compromised if you want to push the bike hard.
I've had wimpy Giant frames in the past but My Ax 29er alloy farme is stiff enough. So I can't see why the alloy T 27.5 wouldn't be adequate for the average rider/ conditions.
Test ride would be in order really.
I went with the Trance 1 for all of the reasons stated above. I couldn't justify the carbon over components so I went with the Trance 1. I run it with a wolftooth 1x10 and upgraded the shifters to XT. I have a set of I9 torches laced to WTB KOMs coming next week to finish it off.
Super nice bike.
Yeah, fork damper quality is a big deal for me too, one reason I'm also looking hard at the Troy XP (Pike RC fork). If the Talas CTD Evo damper can be upgraded relatively cheaply (to FIT CTD Adj?), that could be an option too.
It's roughly $250 for the FIT CTD damper.
Does Fox perform the upgrade or would that be just for the parts and self-installation?
It is tubeless ready and the stock tires seat easily with a floor pump (or at least mine did).
Sorry for the thousand questions but do I need to replace the stock valve? If so, which one do I need?
Just the part. I am currently looking at upgrading a Talas 34 to a fit ctd and that is the price others have paid. It's an extremely easy part to swap out as long as it comes filled with oil... otherwise its a little more work. You can contact Fox directly for the part and ask them. You can also view the service manuals online on how to do it.
Yeah, this will be my first time converting over. Bike came with the Giant P-XC2 wheelset. Was planning on purchasing new valves, Stan's sealant, and rim tape. You're saying that you didn't have to buy any of that? What PSI are you running?
I just eye ball it on the floor pump to around 26-28psi. I could go lower but I ride both trail and urban and this works out great for me. You'll dig it; far fewer flats and it definitely improves grip and smooths out the bumps. I'll never go back.
I could be wrong but I swear that all the goods except the sealant came in the box. It could have also been my LBS taking care of me too though as I cant find any documentation to support it. I'd expect to pay but be stoked to find it in there.
When are you getting it? It's a rad bike! I still stare at it every time I go in the garage.
1 - 17 of 17 Posts
