The new VPP 2 system has the lower link sitting more vertical than the old models. This can be a bit of an issue with mounting a guide up but both will work fine, E-13 and Intense have always gone together until last year and now MRP is what you see a lot on there web site. I belive that its more of an issue involving MS racing ..... I have set up both guides and you do have to rotate them back around the 11 oclock to 10:30 potion. This will help clear the plastic taco from the lower link. I would go E-13 but I am bias. One thing to do with the E-13 lg1 plus is to run the back plate in the wide setting this will help clear the swing link with out having to affect chain line. What is nice about the XTR cranks is that the grany ring tabs are not as thick as other cranks so you will not have to grind them off.
If you go to the Tazer photo thread you can see my bike with the LG1 plus, The bike is the first one in the thread and you can see how it sits it will be the same as how it would sit on your tracer since both frames are very similar in build minus geo
