1 - 5 of 5 Posts
Discussion Starter · #3 ·
Skimming through the pages (36 of those). I saw a few with the DB Coil, but not the Air. The piggy back seems to have enough clearance on the coil, so I can't imagine that the Air's PiggyBack won't fit. Just the question is what else would hit the frame.
Look in the Tracer VP photo thread. I believe someone had an air mounted but they needed a shuttle or they modded the frame. Either way it's not a plug and play shock option.
Discussion Starter · #5 ·
Now I see it. Probably the Carbine has the similar issue.
The Carbine soec the CCDB Air in 200 x 55mm, instead of 57 mm.
Or I might have to consider the Rock Shox Monarch Plus RC3
Thanks for getting the info I need.
1 - 5 of 5 Posts
