I only have experience with TPC+ forks and love the way they work. How does TPC feel in comparison since it doesn't have the floating secondary compression piston?
thanks,
-Sp
thanks,
-Sp
FFD sucks. Its the cheapest of them all. Its nothing more than a port that allows oil/fluid flow through. Hence the name fluid flow damping.Warp2003 said:Yup.... TPC is where Manitou made its fame as bouncy forks.
TPC works just fine. But is a bit bouncy no matter how you adjust it.
FFD is a bit better but not better than TPC+
I've owned both TPC ('00 SX) and FFD ('03 Axel) and found a bit better the FFD. Or may just be that the Axel has adjustable rebound and I found the sweet spot out of it. The fact that it has less parts than TPC is another ticket. A properly engineered part can be better than a bunch of poorly designed parts put together.Hecubus said:FFD sucks. Its the cheapest of them all. Its nothing more than a port that allows oil/fluid flow through. Hence the name fluid flow damping.
Warp2003 said:I've owned both TPC ('00 SX) and FFD ('03 Axel) and found a bit better the FFD. Or may just be that the Axel has adjustable rebound and I found the sweet spot out of it. The fact that it has less parts than TPC is another ticket. A properly engineered part can be better than a bunch of poorly designed parts put together.
The SX used to be very bouncy and while it had decent compression damping at high speed the fork felt a lot more nervous (this opinion is isolated from bike geometry) and bouncy. The Axel felt better at speed and over compromised terrain but I must accept it did dive a lot more than the SX. Axel's compression damping is less compliant and depends more on correct spring selection.
But again, TPC+ is far better and IMHO Manipoo would've just refined the TPC like Zoke did with SSV instead of tossing in another system like FFD.
Correct me if I'm wrong but is actual TPC what it was called TPC+ years ago???
I don't remember quite well but I guess TPC+ referred to TPC plus lockout??
On my TPC manitou I could rearrange the shim stack to provide less or more compression damping. I was under the impression that this feature was carried over to TPC+. So you'd rearrange your shims for less compression damping, if there's a free-bleed screw like there was on the older TPC you'd prbably want to back it out a bit too, and then increase the oil weight.juice said:It looks like we've got a bunch of Manitou damping experts in the room together, so I'll try this question with y'all.
TPC+ rocks (on my '03 Firefly) - super supple on the chattery stuff and resists bottoming better than my SuperT. But... my one big beef is the rebound and compression circuits use the same fluid. I can't slow rebound down enough, but if I go up to 7.5wt fluid, I get too much compression damping, and even at that the rebound is too fast for harsh drops (its great for normal xc). The same beef can be looked at as the rebound damping not having enough range in its adjustment.
Does anyone know if you can easily modify the rebound assembly to get more damping? It didn't look like changing the shims would do much since there's a spring controlling the high-speed damping. I'll have to look closer and maybe just throw caution to the wind and make some changes.
If I can't get this figured out there will be a well-used '03 firefly with TPC+ for sale for cheap...
What you have there is a case where you are just comparing a newer, better fork. Seriously, FFD is crap, its the simplest, cheapest form of damping, drill a hole to let some fluid pass. Thats why its found on only the lowest end of their forks. TPC is waaaayy better than FFD, there's simply no argument there.Warp2003 said:I've owned both TPC ('00 SX) and FFD ('03 Axel) and found a bit better the FFD. Or may just be that the Axel has adjustable rebound and I found the sweet spot out of it. The fact that it has less parts than TPC is another ticket. A properly engineered part can be better than a bunch of poorly designed parts put together.
at 5mph.CDMC said:FFD may be crap, but it sure feels good in my Skareb. In fact, I think it works as well as my Fox Float.
Well then I better slow down because the Skareb feels good at 5mph, 10mph, 20mph, even 30mph bombing down a fire road.Jm. said:at 5mph.
interesting.Homebrew said:I bet the problem with your 2000 SX was the tall elastomer stack and short spring and not on the TPC side. The 2003 Axel has a full length spring with no MCU so no doubt that feels better.
But do you know if there are any full springs available for these models??? If the newer SIX do, they might fit the SX...Homebrew said:I bet the problem with your 2000 SX was the tall elastomer stack and short spring and not on the TPC side. The 2003 Axel has a full length spring with no MCU so no doubt that feels better.
