IMO and experience, an SPV fork is not needed for seated climbing.
Was that a typo? Website says TPC Lockout...DH_WP said:Comes with a lockout and FFD dampning ..can I replace that with TPC + ?
It comes with TPC, not FFD.DH_WP said:Comes with a lockout and FFD dampning ..can I replace that with TPC + ?
Sorry should of said ... the 05 Black Platinum comes with IT travel (0-120mm)FFD and a TPC lockoutHecubus said:It comes with TPC, not FFD.
So one could save money and get it (really intrestested in the weight and IT travel and put my own TPC + system in and loose the lockout ?anand said:Overall, it looks like Manitou is moving the black line down with FFD instead of TPC. They call it FFD with TPC lockout but it looks like it is just FFD with a cheap TPC compression piston.
Thats a typo TPC/FFD only refers to the compression circuit. You can only have one or the other.DH_WP said:Sorry should of said ... the 05 Black Platinum comes with IT travel (0-120mm)FFD and a TPC lockout
http://www.stevecramerproducts.com.au/
I am confused. It looks like the rebound is just a port system with a second top port piston for the compression. Hence the twin piston (TPC) name. This is not the same as the nice, shimmed system used previously in the TPC and TPC+ systems.Hecubus said:Thats a typo TPC/FFD only refers to the compression circuit. You can only have one or the other.
Well, as there is very little info about the recent TPC (and I haven't ripped open a Manipoo lately) I can't tell the new TPC is equal or different to the old TPC (Normal or Sport). I'd like to know that too. Most probably with the forks which have a lockout or adjustable compression damping it is more likely to be TPC+ (The compression piston is the main - and huge - difference between TPC and TPC+).SinglePivot said:so it seems like the consensous is TPC+ is the shizznit. So in this thread, is the new 05 manitou TPC just the plain jane "TPC" or is it in actuality "TPC+" or Evolve damping make TPC+ redundant in their lineup?
With the travel adjust of the 03 shermans, is SPV really necessary for seated climbing? They feel substantially stiffer than the longer travel setting (showroom).
thanks,
-Sp
While most riders will not notice it the fact is the front end DOES move during seated climbing and flats. It will vary with pedaling style but its there. It's particularly more apparent with longer travel forks. SPV also helps in other aspects such as reducing fork wollow and brake dive. They alse tend to keep more travel readily available since the fork is not compressing unecessarily. Although I have yet to try it it seems SPV Evolve could possibly do a very good job of replacing TPC and TPC+. The platform. Sensitivity is supposed to be significantly improved and the adjustable platform with the volume adjuster to go from linear to bottom out resistant seems to easily fulfill both roles and more.Warp2003 said:SPV should not be necessary for seated climbing. It may help your mind as you will not see the front end moving a little. SPV is better for people who like (or have to) pedal standing. But it's a matter of opinion so you will hear different approaches to his.
I've gotta disagree with you on this one. TPC+ is sweet because you can run it plush at the top of the stroke so you're super smooth and fast on the small, chattery stuff without plowing through your travel and taking a header when you hit a decent size bump or compression dip. No matter what kind of riding you do its better to have less compression damping at the top of your stoke.Hecubus said:TPC+ resists bottoming out much better which is very likely the reason it is only implemented on more aggressive forks. TPC+ on the average mountain fork will just end up giving most riders unusable travel towards the end.
I agree with you. That is how I used to run my old X-vert Super (that had TPC+). With my new Black Super (with TPC) I have to run it much firmer to prevent bottoming. TPC+ was great!juice said:I've gotta disagree with you on this one. TPC+ is sweet because you can run it plush at the top of the stroke so you're super smooth and fast on the small, chattery stuff without plowing through your travel and taking a header when you hit a decent size bump or compression dip. No matter what kind of riding you do its better to have less compression damping at the top of your stoke.
I agree with you but you are missing my point.juice said:I've gotta disagree with you on this one. TPC+ is sweet because you can run it plush at the top of the stroke so you're super smooth and fast on the small, chattery stuff without plowing through your travel and taking a header when you hit a decent size bump or compression dip. No matter what kind of riding you do its better to have less compression damping at the top of your stoke.
Yeah, you're right. I had a brainfart on there and was pointing at the wrong side of the piston.Warp2003 said:MY GUESS....
Add shims on the opposite side of the spring if you want to increase rebound damping.
