Am I losing my mind? I have the Stylo ss crankset, maybe 2005 vintage, which comes with the silver/black bashgaurd. Pretty much worthless as a bashgaurd, and I don't typically find myself in bashgaurd situations anyway on the single, so I want to remove it. My initial attempt failed when I was replacing the stock chainring with a salsa ring, as I learned the existing chainring bolts/nuts were too long, and, without the added stack height of the bashgaurd, they would not seat. No prob I thought, I will just spend $5 and get some "bmx" bolts, which I think are cut shorter (both nut and bolt). Thought I was embarking on a 5 minute exercise last evening, but spent well over an hour trying to get the frigging shorter bolts/nuts to seat without the guard. WTF? I finally ended up adding the bashgaurd back in, and using the short bmx nuts with the long stock bolts, and have three of the four seating well. The forth is still spinning quite free, won't bite. Of course I do not have a chainring nut wrench/tool thingee, as I prefer to cut little circles in my fingertips while trying to hold the sharp edged nut in place to get it to bite. Is this nightmare solved by simply having the right tool? say it isn't so. Who else has removed that aluminum foil bashgaurd on the stylo... please share your story. thanks
