Best bet and cheapest, would be to buy the Beam type. Also, Ideally you need two wrenches on for 0-60 in/lbs and 0-600 in/lbs. Park tools are good for both, but both will cost about ~35 each. What I did was buy the 0-60 in/lbs Park for ~30, then went to sears and bought the Craftsmen 0-25 ft/lbs for ~20. If you do the conversion the Craftsmen becomes a 0-900 in/lbs wrench. So you would loose a little accuracy, but at the higher torques not a problems. Also, on the Park tools website, all torque values are listed both in measurements, were applicalbe.
